Mid Range Speaker Suggestion
Hello All,
I am a newbie who just purchased a 96 s-10 4 dr, 4 wheel drive. From day one only sound came out of one speaker (right rear passenger door). Fade and blance had no effect. Thinking stock radio bad, replaced with a sony cdx-gt200, with the after market pulg and play wiring harnesses. No amp or sub. Guess what, sound only from same speaker. Well I guess there is a problem with the speaker wiring or maybe there are no speakers (previous owner removed?) Anyway I will pull off the door panels this weekend and I will replace stock speakers with aftermarket and check wiring . After reviewing this site I believe there are 6.5 all around in doors, is this correct. Any suggestion as to what speakers (mid price range) to get for good sound that mount with little effort or additional speaker adaptors. Thanks to all for any input or suggestions to problem fix.
hmm....lets see. i know the Infinitys are nice, at about $100 a set via best buy and cheaper online. i have also heard good things about SPL speakers with there 5 way 6x9 and all - power acoustiks are said to be great but only if run with an amp.
check out woofersetc.com, or onlinecarstereo.com. They both have pretty good listing of manufacturers. Infinity's, Diamonds, CDT Bostons Acc, MB Quart used to be pretty good for speakers, (not really subs).
I would look at getting a component set for the fronts, and then just some coaxials for the back doors. I mounted my CDTs components in front doors and put the tweeters in the factory dash location.
Thanks to all replies so far. When I am replacing the speakers should I go with the same model and type for all 4 doors or is it better (sound wise) to put different types in the front and rear. Suggestions very much appreciated. Thanks again
i would have to say that you dont have to go with the same models and such, but i would if i were you. And i would go with Pat (hillbilly) on this one for the component set up front and coax in the back. that will give the best sound and the mid-bass speakers will be good for the lil extra bass since no subs will be used.
