Need Help - Best Place for Constant 12V+ and Switched 12V+.
Old Jul 26, 2015 | 03:46 PM
adc's Avatar
adc
adc is on a distinguished road
Question Need Help - Best Place for Constant 12V+ and Switched 12V+.
All,
Need a little help.
I've gone thru the sticky on Stereo Wiring and Install Parts didn't really find a concise answer.
My rig is a '97 4dr 4wd.
While in the process of replacing the Ignition Switch I came across a previous owner's attempt at wiring a Panasonic head unit.
He/she tapped into the Ignition Switch Harness 12V+ the large red wire, and also tapped into the 12V+ white wire of the same harness which is designated Secondary Ignition.
In addition to not following color coding in several places the previous installer has twisted pairs of smaller gauge wire to make a larger gauge wire.
I would like to correct a few of the previous owner's wiring "techniques".
My immediate need is;
Where is the best place(s) to connect to the Constant 12V+ and Switched 12V+ voltages other than the Ignition Switch Harness?
Thanks in advance.
Al
Old Jul 26, 2015 | 08:14 PM
lazyboyjake's Avatar
lazyboyjake is on a distinguished road
If you're doing this for your radio, you should have those coming from the factory harness unless that's been removed.
Old Jul 27, 2015 | 05:58 PM
adc's Avatar
adc
lazyboyjake.
Since I don't want to cause any more problems before I get the truck running, I've opted to install the new Ignition Harness without tapping it to see if these taps are really being used.
If the radio doesn't work I'll temporarily tap them, and hook up the radio properly at a later date if the original OEM connector is still there.
Update:
The new Ignition Harness is in without taps.
I've left the 2 wires that were hooked to the harness off.
The 2 wires are black taped, and dangling at the moment.
Truck starts. Runs good.
Radio works. It's apparently installed correctly.
But, there is a small LED light on Headlight Control Panel that is not blinking anymore. I never was sure what that light was for. It use to blink about every second or two.
I guess I'll check that out now.
Thanks.
Al
Old Jul 28, 2015 | 12:41 AM
adc's Avatar
adc
All,
Final update:
Wedged way up under the dash I found an aftermarket Keyless/Alarm System.
Will correct previous owner's wiring "techniques" and button her up.
Regards,
Al
Old Feb 19, 2016 | 08:32 AM
kjbrown97's Avatar
kjbrown97 is on a distinguished road
My radio and overhead display won't turn on unless I have the constant power and switched power wires together, does anyone have any idea which fuse this would be ?
ussexplorer
Apr 28, 2013 01:50 PM
Tinted
Nov 30, 2011 02:07 PM
wirespider01
Nov 13, 2011 04:12 PM
radiokid
Dec 28, 2010 09:00 PM
firefighter4
May 11, 2010 06:45 AM
