new amp
Old Aug 14, 2007 | 06:29 PM
hockeykid15's Avatar
hockeykid15 is an unknown quantity at this point
Default new amp
driving to work today my amp blew up on me.... literally!!! and apparently circuit city doesnt have any record of me purchasing a protection plan. so since i have to spend money i want to know what would be a good replacement. i had a kicker kx350.2 and they dont make it anymore. i would like to stay with kicker since i have the bass control **** for a kicker. but im open to any other suggestions. i am running a 12" kicker comp (not comp vr). and i would like tostill be able to have a control ****.... girlfriend doesnt like the bass!
thanks in advance
Old Aug 14, 2007 | 09:43 PM
hillbillyinOhio's Avatar
Default RE: new amp
ZX350.2
ZX300.1
ZX400.1
or click here
Old Aug 14, 2007 | 09:51 PM
Default RE: new amp
im assuming that the 350 you have there is the same as the one i had just the newer model?
and what exactly is the difference between 1 and 2 channel amps? is it just that 2 channels can run 2 subs or is there more to it?
Old Aug 15, 2007 | 12:10 AM
Default RE: new amp
a mono amp is more effecient for driving subs. whether it be 1 or 8 subs. If I were in your shoes and were only planning on using that one sub, I would get a mono amp.
Old Aug 15, 2007 | 09:46 AM
Default RE: new amp
ok then the 300.1 it is. thanks for the help
Old Aug 15, 2007 | 01:47 PM
blazinloud's Avatar
Default RE: new amp
you'll only get 150 watts outta that if your sub is a single 4 ohm
Old Aug 15, 2007 | 02:58 PM
Default RE: new amp
so would it be better to get a 2 channel amp and bridge it again?
Old Aug 15, 2007 | 05:34 PM
Default RE: new amp
probably, if your sub is a single vc.
Old Aug 15, 2007 | 06:17 PM
Default RE: new amp
well thats what i have. i went and bought the 300.1 today and i did notice that it was quieter than my 350.2. so i will bring it back and get a differentone. circuit city doesnt have a 350.2 they only have the 300.1, 400.1 and a 200.2 that are all about the same price. would the 200.2 be about the same as the 300.1? but i may have to take a little bit of a drive because the store i went to said that there was one about 40 mins away that had the same amp i had. i am assuming that that would be the way to go?
Old Aug 15, 2007 | 07:18 PM
Default RE: new amp
the 200.2 will only give you 200 watts at 4 ohms i believe. wont be a noticible difference, and you might try to compensate by cranking the gain, therefore roaching your sub.!
