New amp
Old Apr 6, 2007 | 10:13 PM
blznlowxtreme's Avatar
blznlowxtreme is an unknown quantity at this point
Default RE: New amp
drop it down to two ohms and it will make a big differnce. i had a kicker solo-baric and had the same problem till i dropped it to two ohms. less ohms= more power to the subs. it wont hurt your sub and your amp will hold up to it fine
Old Apr 9, 2007 | 04:21 PM
RCarp48's Avatar
RCarp48 is an unknown quantity at this point
Default RE: New amp
Birdge them at 2??? my amp is 2 ohm stable but not bridged wil thi still be ok??
Old Apr 9, 2007 | 05:28 PM
eshballa5's Avatar
eshballa5 is an unknown quantity at this point
Default RE: New amp
Its not possible to have 2 4ohm DVC subs and have both of them bridged to the amp and have a total load of 2 ohms. It would be either 1 or 4. Since your amp has a minimum impeadence load of 2 ohms then you cant bridge it or wire it lower than 2 ohms.
Old Apr 9, 2007 | 09:24 PM
Default RE: New amp
if your amp says it willl run 2 ohms it can hold up on one ohm, some people will say not to do it but i have ran it like that and didnt have any problems, my system i have now is ran at .5 ohms and my amp is only supposed to handle 1 ohm and it handles it fine. and it deally make a difference.
Old Apr 10, 2007 | 11:03 AM
blazinloud's Avatar
Default RE: New amp
crank the bass boost, the gain, put everything up to +10 and wait for the magic smoke.
but really, having everything cranked up is not good......especially the gain. I doubt your going to get the volume you want with that amp.
Old Apr 10, 2007 | 06:35 PM
eshballa5's Avatar
Default RE: New amp
i agree with blazinloud, but not with blznlowxtreme. Lanzar isn't the greatest brand and will probably not hold up under 2 ohms for a long time. if your looking to blow this amp after maybe 6 mo then sure go ahead and do it.
Old Apr 10, 2007 | 09:33 PM
blazinloud's Avatar
Default RE: New amp
what? blznlowextreme is totally wrong.......just cause it can run at 2 ohms does not mean it can be ran at 1 ohm......usually it voids warranty, and creates more problems........alot of amps will not run at all with an ohm load lower than its rated for.
dude, dont give someone trash advice.
Old Apr 10, 2007 | 10:09 PM
hillbillyinOhio's Avatar
Default RE: New amp
Wow, i just came upon this thread again. blznlowextreme, you are giving seriously incorrect and damaging advice. If an amp states that it is 2 ohm stable, then that is what the manufacturer states is the lowest safe impedance level, and running it below that impedance can and usually does lead to destroying the amp. Some higher end companies have amps that are stable below 1 ohm, but def not in this case. In fact, most amps will go into protect if dropped below a certain impedance level.
That amp is not 2 ohms stable when bridged, only in stereo.
Rcarp, Unhook everything. Start over again. First off, where is the amp grounded at? Once you have a good ground, then go forward. If you need a location for your ground, PM me. I would wire your subs to 4 ohms bridged. Then go about setting your amplifier
Old Apr 10, 2007 | 11:49 PM
eshballa5's Avatar
Default RE: New amp
I agree with everything that hillbilly says. The most your going to get with that amp is wired at 4 ohms bridged. sometimes thats the way it has to work
JohnBarJB
Sep 28, 2020 07:34 PM
dj00140
Apr 13, 2011 10:40 AM
dougs10
Dec 14, 2010 03:24 PM
bfsmith72549
Nov 1, 2010 05:44 PM
RCarp48
Apr 2, 2007 07:19 PM
