OEM Speaker Sizes
Old Nov 11, 2008 | 07:54 PM
Duntov's Avatar
Banned
Duntov is an unknown quantity at this point
Default RE: OEM Speaker Sizes
I thought about adding resistors to the speaker wires. Since I found two new OEM AC Delco 8 ohm 4 x 6 speakers, I don't needto bother with the 4 ohm Pioneer speakers.As far as I know, theonly thing the Pioneer 4 ohm speakers have that theAC Delco 8 ohm speakers don't have is tweeters. I don'tthink I needtweeters.
Besides, I think I fixed the original AC Delco speakers when I switch the speakers from one side to the other. It must have been loose or poor contacts with the speaker wires after all they are 18 years old.One speaker had very little sound and after I switched sides with them, both speakers seem to be working fine now.
Old Feb 21, 2009 | 09:20 PM
Cavalier z24's Avatar
Cavalier z24 is on a distinguished road
thanks for the info
Old Feb 24, 2009 | 06:23 PM
86Blazer4x4's Avatar
86Blazer4x4 is an unknown quantity at this point
a good source for wiring and speaker sizes and ect is www.the12volt.com .
Old Feb 24, 2009 | 07:42 PM
my1blazer's Avatar
my1blazer is an unknown quantity at this point
sorry its my fristtruckbut i know thats its a 1996 but on the door it has LT but its a 4 door and my mom says its a s-10 blazer and theirs no speakers at all so how would i find out what kind of truck it is and the speaker size all around??????????
Old Feb 24, 2009 | 09:56 PM
in most chevrolet vehicles its either a 4x6 or a 6x9. in that one i believe on the top of my head there will be 4x6 in the dash. 6inch rounds in the door and 6x9 in the rear.
Old Feb 25, 2009 | 07:34 AM
jagblazer01's Avatar
ORIGINAL: 86Blazer4x4
he only has 6x9s if its a 2door...he said his is a 4door. 4doors came with 5.25" in the rears and 6.5s up in the front doors
Old Feb 25, 2009 | 12:07 PM
oh i didnt realize that i thought it would be like the older body style s10. note taken.
Old Feb 25, 2009 | 07:15 PM
hillbillyinOhio's Avatar
ORIGINAL: in4lo
ORIGINAL: vin791
just wire in resistors b/t the radio and the 4 ohm speakers?
This is a good idea... a 4 ohm 100 watt resistor should do the trick. I say 100 watt because better safe than sorry. You don't want resistor guts splattered all over behind your dash.
ORIGINAL: Duntov
THIS WILL NOT WORK. The resistors will not be able to handle the heat generated.
Old Mar 14, 2009 | 05:14 PM
ok my rear door speakers the rubber rings are blown out and they are completely round circle how can i measure them for the size? is it across or all the way around?
Old Mar 14, 2009 | 07:15 PM
Outsydr's Avatar
Outsydr is an unknown quantity at this point
the size is diameter so measure across but let me save you some time, 94 has 6 3/4" in the rear doors (I replaced mine with 6 1/2" easily enough though) and 4"x6" in the dash
