OEM Speaker Sizes
#24
someone else mentioned that the rear doors are 5 1/4"? now i haven't done alot of these trucks, but i've noticed that on the LT's, the rear doors have been the same as the front. maybe because of the higher trim line? who knows what the hell goes on @ GM.
#25
All 82 to 04 S-10s and Blazers take 4x6s in the dash
All 82 to 04 S-10s take either 4x6s or 4x10s in the rear. Just look at it, if its a huge oval, its a 4x10, if its oval but closer to a circle , its a 4x6.
All 83-94 2 door Blazers use 6x9s in the rear
All 83-94 4 door blazers use 6 3/4s in the rear
All 94-04 S-10s and 95-04 Blazers use 6 3/4s in the front doors
All 95-04 Blazer 2 doors use 6x9s in the rear
All 95-04 4 door Blazers use 5 1/4s in the rear there are a few variances of this. some blazers come with tweeters in the dash. the info above will hold true 90% of the time, but it's always safest to check for yourself.
#26
as for what truck you have, the "S" is for the smaller line of trucks the General made (S10 is Chevy, S15 is GMC) if it's a 4WD truck (regardless of Chevy or GM) it's gonna be a "T" truck (T is for 4WD). so, if your truck is a Chevy, and it's 2WD, then yes, it'll be a S10 Blazer.
#27
OEM Speakers (resistors to change speaker impedence? NOT)
I was just reviewing the post on OEM speakers. Not too sure of the newer GM or Delco sound systems however - the older units 'generally' had a speaker impedence somewhere around 10 ohms.
As far as using a resisitor between the stereo and speaker - NOT recommended. Although the same units are used to measure the two, there is a huge difference between resistance and impedence.
It may work temporarily, eventually the output amp in the stereo will likely overheat and burn out. You 'may' get lucky and only fry the resistor but usually it's the stereo that ends up getting the worst of it. This is especially true at higher volume levels.
Better to replace the speakers with the same impedence or the stereo.
Just a word from someone that has learned the hard way and has worked in audio electronics since the 70's.
Best of luck.
Best of luck.
#28
Maybe it was just me, but I recently replaced my factory speakers in my 98 S10 Blazer with BOSS speakers and found that my dash had factory installed 1" tweeters and not 4" x 6" speakers as all the guides say.
I did end up replacing the 5 1/4" in the back doors with 6 3/4" speakers =P
#29
yes, there is a 1" tweeter in there, but it's still a 4x6 plate design that's used.
and a little FYI, not all 4x6 plates simply "drop in" on these 2nd gen trucks. i know that RF, Alpine, and Sony 4x6 plates need a little "tweaking" to make them fit. very little actually, but still not a complete drop in.
#30
my bravada has the factory tweeters in the dash and there still decent,the hold there own with the 4 3-way 6.5s i have in my doors..and thank you i wasnt aware that the rear doors on my bravada were 5.25..that would explain the hassle i had fitting my 6.5s in that spot
