Only one speaker work ???
Old May 12, 2023 | 03:43 AM
jimmy_for_ever's Avatar
jimmy_for_ever is on a distinguished road
Default Only one speaker work ???
Hello everybody
I have a problem with my GMC JIMMY 00 after I install Sony xav-100 I only get sound from front right speaker all other speakers stopped working. I reinstall the factory radio also it is the same problem.
Anyone know how can I solve this problem ?
thank you
Old May 14, 2023 | 05:09 PM
That the problem exists with the old radio reinstalled means that that the issue is not the radios. You will have to to a continuity check for all the wires. I'd start first with the plug that connects all of the speaker wires to the radio since that is the one common part of the speaker wiring and where damage to the wiring to those three speakers could have happened at the same time.
Old May 16, 2023 | 03:40 PM
The problem solved thank you christine
Old May 17, 2023 | 03:44 PM
How did you fix it?
Old May 19, 2023 | 03:04 AM
How did you fix it?
The door wiring harness was loose I try to push both connectors together and it works
Dano01
Sep 26, 2011 07:20 PM
bradly2795
Mar 28, 2010 07:40 PM
88s10Blazer
Jan 3, 2010 02:20 PM
BLK85
Mar 16, 2007 09:44 PM
ige2201
Feb 9, 2006 03:31 AM
