optimum
Old 10-14-2007, 07:04 PM
blznlowxtreme's Avatar
blznlowxtreme is an unknown quantity at this point
Default optimum
i was trying to remember the difference between the colors. i know they have a yellow, red and blue cant cant remember what each one is designed for
Old 10-14-2007, 07:08 PM
mdehoogh's Avatar
Default RE: optimum
its optima but i dont know anything about the differences
Old 10-14-2007, 07:15 PM
Default RE: optimum
yea i noticed that after i already posted it.
Old 10-14-2007, 07:25 PM
EuroGoldLS's Avatar
EuroGoldLS is on a distinguished road
Default RE: optima
Yellow top:
These batteries are dual purpose. They are designed for engine start and deep-cycle applications for use in vehicles with large accessory loads. Side and clamp-on top post.
Blue top:
These batteries are designed for engine starting applications. They are NOT recommended or warranted for use in deep cycle applications. Screw-on and clamp-on top post.
Red Top:
These batteries are designed for engine starting applications. They are NOT recommended or warranted for use in deep-cycle applications. Side post and clamp-on top post.
The rest of the specs can be found at: http://www.optimabatteries.com/optim...specs.php#red1
Old 10-14-2007, 07:27 PM
Default RE: optima
thanks, i thought the yellow top was the most common, thats probably what i will be running so i wanted to make sure
Old 10-14-2007, 07:29 PM
EuroGoldLS's Avatar
Default RE: optima
Its best to go with a Yellow top and upgrade your big three to a lower wire gauge
Old 10-15-2007, 08:39 PM
Default RE: optima
yea i know. thats what i have planned, going to use 0 gauge
Old 10-15-2007, 09:18 PM
jagblazer01's Avatar
Default RE: optima
i run a yellow top under the hood on my truck and ive had no problems.....the blue tops are more marine batteries anyway so i wouldnt go with them.
Old 10-17-2007, 12:12 AM
bobditts's Avatar
bobditts is an unknown quantity at this point
Default RE: optima
ORIGINAL: EuroGoldLS
Blue top:
actually the blue top IS a deep cyle battery. Per the website;
"Deep cycling and cranking power all packed into one battery. "
Old 10-17-2007, 05:22 PM
EuroGoldLS's Avatar
Default RE: optima
I copied and pasted those strait onto the post. Something must be contradictory...
