Power door locks
Old Nov 8, 2007 | 08:37 AM
drperry's Avatar
Default Power door locks
Okay, so awhile back I aquired some factory GM power door lock units...
The only problem is last time I looked under the plastic, there was a nice piece of door covering the lock from any type of easy access...
Is my only option lots of cursing and swearing, or is there a magic way that I don't know about to drop in the power units?
I know I'll have to run my own switches... As the switch panel that came with the locks are from a 4 door with power windows, lol.
Anywho, tips, tricks, suggestions for the power lock installation are all welcome!
If need be I can pop my door open and take a pic of what I mean...
Old Nov 8, 2007 | 01:45 PM
RCars2's Avatar
RCars2 is an unknown quantity at this point
Default RE: Power door locks
Um, im confuzzled. Ya might want to take a pic because i have no clue as to what part of the door thats blocking it. Unless you mean the inner metal shell of the door?
Old Nov 8, 2007 | 01:55 PM
rriddle3's Avatar
I guess what you're referring to is the 'water shield'. If so, the Haynes manual says "For access to the inner door, carefully peel back the plastic water shield. If you're careful, it can be reused." Real detailed info, huh?
Old Nov 8, 2007 | 03:33 PM
cloak01ls's Avatar
cloak01ls is an unknown quantity at this point
Not sure how the factory GM locks work, but if it is just a a basic actuator then it should strap to the door lock rod somewhere...
maybe this helps, maybe it doesnt... http://www.a1electric.com/door_locks.htm
Old Nov 8, 2007 | 06:32 PM
drperry's Avatar
It's not the plastic water shield...
Directly over the whole latch assembly, the part that locks and keeps the door shut, there's a chunk of metal covering where it sits...
I'll go snag a pic so I can show ya... or see if I've got one of my door already.
After finding out how my door looks inside, it makes me kinda wish that I'd gone the actuator route instead of the factory GM route, lol
Deezy13
Feb 14, 2009 09:30 PM
kpiper
Dec 30, 2007 01:41 PM
truck608
Oct 14, 2007 11:56 PM
Craig Austin
Nov 14, 2006 01:20 PM
Craig Austin
Oct 22, 2006 06:48 PM
