Power Wire
Old Mar 14, 2007 | 10:59 PM
03blazer's Avatar
03blazer is an unknown quantity at this point
Default Power Wire
I have an 03 blazer 2 door and i was wondering wherre the best spot to run the power wire is? Thanx for your help
Old Mar 14, 2007 | 11:04 PM
blazinloud's Avatar
Default RE: Power Wire
grommet, passenger side firewall.
Old Mar 15, 2007 | 12:37 AM
hillbillyinOhio's Avatar
right above your left foot in the passenger side. very large grommet, antenna wire runs through same grommet.
Old Mar 15, 2007 | 01:44 AM
03blazer's Avatar
Thanx ill have to check it out, jus pull up the carpet and it should be around that area?
Old Mar 15, 2007 | 09:24 AM
drperry's Avatar
You should be able to see it without lifting the carpet...
Just stick your head underneath and it should be visible with the interior light on...
Old Mar 22, 2007 | 12:44 PM
Madwahoo's Avatar
Madwahoo is an unknown quantity at this point
Ihave a question. After you go threw the firewall, do you go under the carpet or down the side of the truck to get power to the rear??
Old Mar 22, 2007 | 01:53 PM
drperry's Avatar
under the carpet is easiest, until you get into the rear of the truck, then it can come out from under the trim panels
Old Mar 22, 2007 | 02:48 PM
jagblazer01's Avatar
what size power wire? i have 1/0 ga. running under my truck and drilled up into the back
Old Mar 22, 2007 | 03:36 PM
I had 4 ga ran under my carpet, and now I have 4 runs of 0 under my carpet. removed the entire interior to do that, but you cant even tell its in there.
Old Mar 22, 2007 | 08:29 PM
blazinloud's Avatar
being able to see wires is like having too much mayo on a whopper jr.......just ruins it.
chris015
Jul 8, 2012 01:19 AM
DJ 4x4
Sep 26, 2011 09:44 PM
bubba181x1
Mar 12, 2008 02:05 AM
alpinejimmy
Jan 20, 2006 09:38 AM
massaudio
Nov 17, 2004 11:22 AM
