Powermaster XS D680
ORIGINAL: NoPh33rRaCiNg
you only need a battery isolator if your gonna be playing your stereo a lot with your car turned off
I used a Stinger but I'm sure Power master is just as good.
ORIGINAL: TheBrettster
You would need an isolator if you're running more than one battery. An isolator will allow you to drain one battery that you would use for auxiliary but keep the main battery still charged. This will also help even if you're car is on. When i had my killer system i was running around 5000 watts RMS with 3 batteries in the back and one up front, I isolated all 3 so the front one wouldn't be effected.
