Question about stereo instalation
Hi guys!
I plan to upgrade my sound systeme and i have a few question for you
My blazer is a 99 LT 4dr with 6.5" speaker in all 4 doors and 2 tweeter in the dashboard... Everything oem.
Setup would be :
(4) Door speaker 6 1/2 Alpine SPS-610
(2) Dash speaker 4x6 Alpine SPS-406
HeadUnit Alpine CDE-143BT
Without amp and sub (planned for later)
I'd use oem wiring, cut the wire right before oem speaker and use push-on connectors, my question is about the 2 dashboard 4x6 instead of the tweeters... Can i put these there without other wiring modification?
Also i have a problem with my left rear door speaker, someday he is working someday he is not...
I check wire at headunit harness and in the door evrything look fine
Is it possible that the delco headunit cause that?
Thanks for your help guys!
Setup would be :
I would switch it out and see how it goes.
http://i58.servimg.com/u/f58/16/04/12/87/image10.jpg
Also what do you guys think of my speaker/headunit choice? And wich amp/sub should i use with those?
I choosed these speaker cause i got the 2 4x6 for free so..
Thanks!!
Sorry for wrong advice op
Thanks for correcting me Rich
Edit: alpine makes great stuff op, I'm sure you'll like it.
Gomli
Jan 20, 2012 10:26 AM
ohboyseth
Sep 24, 2009 03:15 PM
