radio display doesn't always work
Old Jan 31, 2010 | 01:52 PM
Mczuk's Avatar
Mczuk is on a distinguished road
Default radio display doesn't always work
I'm not sure if anyone else has had this problem or not but here goes.
The display on my stock AC delco radio would suddenly go black, sometimes it wouldn't some on when the truck was turned on, other times it would just black out while driving. I though I just had to live with the problem but my wife (gotta give credit where credit is due) found out the if you turn the high beams on (while in DRL mode, ie. lights off) the radio display would come back on. It works everytime (for me at least), and hope this thread can help others as well.
Old Jan 31, 2010 | 01:58 PM
papacope's Avatar
Wow, that's weird, then again I have witnessed some of the weirdest electrical problems with Blazer/Jimmys.
Old Feb 4, 2010 | 08:27 PM
84BlazerS10's Avatar
Sounds like a wire is shorting out have you tested the wiring?
Old Feb 5, 2010 | 04:19 AM
Mczuk's Avatar
haven't tested anything yet, found out the heated mirror switch turns on the brake lights (they work alright when turned off). I assume there is a bad ground or something somewhere but haven't gotten around to searching for it yet.
Old Jun 27, 2010 | 09:06 AM
glued2it's Avatar
glued2it is on a distinguished road
I have the same problem, the display will go off when the headlights are turned on. (high or low beams)
I take it that noone has found a solution?
Old Jun 27, 2010 | 09:09 AM
glued2it's Avatar
oops! I double posted!
lazer2000
Sep 16, 2012 11:16 PM
Moses
Jan 23, 2012 07:32 AM
carap915
Feb 3, 2011 09:44 AM
royser
Nov 9, 2010 10:12 PM
hotrod28
Nov 16, 2006 11:25 PM
