Radio Problems
Old Jun 8, 2014 | 09:31 PM
1992ChevyBlazer's Avatar
1992ChevyBlazer is on a distinguished road
Default Radio Problems
Hello All,
Ran into a problem with my radio today.
I took the plow mount off my truck and turns out they had wired the radio into the plow witch was wired into the ignition... instead of the radio fuse.. To me I thought It was stupid..
anywho. I got 12.44 volts on the main power wire when the ignition is turned to the on/run or accessory and 0 when in the off position
I got 5.32 volts on the memory wire and that's using the harness ground.
The problem is, The radio didn't have a problem before I messed with the plow and now it will not turn on.
15amp radio fuse is good, 30 amp ignition fuse is good, 7.5amp on radio fuse is good. And it is getting power. But it will not turn on, will not do anything
Radio is a boss 637 UA... I know boss isn't that great but I had just bought the radio in march...
Old Jun 9, 2014 | 10:06 AM
altoncustomtech's Avatar
The memory wire is the main power wire. Think of an aftermarket amplifier with it's BATT +, Ground - and remote. The (typically) Yellow memory wire is the BATT +, the Black wire is of course the Ground -, and the Red wire is the remote. The HU isn't going to turn on without a full 12v on the memory wire. You're going to need to look at all your connections, fuses, etc. and try to figure out why you only have a little over 5v on that wire. Once you get 12v back on that yellow memory wire the HU should power right back up.
Boiler20
Oct 19, 2013 03:53 PM
dan_t
Nov 25, 2010 08:35 PM
iamchevyman5
Nov 7, 2010 01:20 AM
black19
Jun 22, 2006 03:35 PM
