Radio Replacement Questions
Old Jul 21, 2009 | 05:08 AM
brian400ex's Avatar
brian400ex is on a distinguished road
called crutchfield and they never heard of your tach not working.
Old Jul 22, 2009 | 11:04 AM
brian400ex's Avatar
nobody can confirm what crutchfield said. will the tach still work on a 2003 with an rds radio if i go to an aftermarket hu?
Old Jul 22, 2009 | 01:45 PM
jonnycakes's Avatar
jonnycakes is on a distinguished road
Default 2001 Blazer - How do I install a Pioneer HD Tuner??
I have a 2001 chevy blazer and I am looking to run a subwoofer cable cleanly from the HU to the cargo area, any tips or tricks?
Old Jul 25, 2009 | 10:16 AM
mathyoumac89's Avatar
mathyoumac89 is on a distinguished road
i have a 96 blazer and i ran the wires from the head unit across the steering column inside the dash and down past the parking brake and all the way to the back i tucked it under the plastic on the edge of the floor so it cant be seen at all its pretty clean look for small openings to run the wires through just make sure nothing is going to pinch or squeeze the wires where you run them
Old Sep 11, 2009 | 02:25 PM
GMJim3687's Avatar
GMJim3687 is on a distinguished road
Default You wont lose tach
The rds runs through the class 2 data bus to figure out what the tach signal is. there is no tach wire that goes to the radio. so you will be fine with replacement of the factory radio with the after market. still unsure if the 03-05 blazer extreme dash bezel will fit into a standard s10. because they redesigned the frame of the dash. everyone ive talked to either fiberglassed the dash or went with a flip out. even tho a double din navi looks so much nicer.
Old Sep 11, 2009 | 05:02 PM
RangerG's Avatar
So if you have a 03-05 Blazer, and not S10 I should be good with fitting a double din in there? I found a double din on crutchfield and it says it should fit.
Old Sep 19, 2009 | 01:09 AM
pmpnu2's Avatar
pmpnu2 is on a distinguished road
to my knowledge, as far as the blazers go, they changed to the double din in 03. i have an 01 xtreme and i cant fit a double din...
edit: also my tach still works fine...
Old Nov 28, 2009 | 10:36 AM
jjrock5's Avatar
jjrock5 is on a distinguished road
Can somebody tell me if it's possible to run an aftermarket sub and wire it into the stock radio? Somebody I know is saying it's impossible and I know it is possible.
Boiler20
Oct 19, 2013 03:53 PM
dan_t
Nov 25, 2010 08:35 PM
iamchevyman5
Nov 7, 2010 01:20 AM
black19
Jun 22, 2006 03:35 PM
