Removing Aftermarket CD Player?
The blazer I just bought has an aftermarket stereo in it, but the faceplate was stolen. I want to remove the stereo and put a new one in, what's the easiest way? Will I need to remove the dash as if I was removing a stock CD player, or is it easier since there is already a single DIN and stereo in it?
1996 Chevy Blazer. |
It depends on the make of the stereo. Many after market stereos use release keys that release the CD player from the mounting cage. A stereo installation shop in your area may even be kind enough to supply you with the keys, or sometimes you can make your own from a really thin piece of metal. The key slips in between the CD player and the mounting cage, and then the CD player just slides out. You wouldn't need to take the dash apart at all.
if your replacing the stereo with the same style , Brand new ones come with the tools to release
if you going back to stock , remove dash trim and all the bolts that hold the adapter plate will be accessable |
(Post 585521)
Originally Posted by rexazz2
(Post 585523)
if you going back to stock , remove dash trim and all the bolts that hold the adapter plate will be accessable I looked around on YouTube and I guess some poeple just use really thin butter knives or similiar to get the CD players out. I might try that or just head to a audio shop and see if they will let me use their keys. Thanks for the replies guys, I will update soon. |
You do not need the release keys to get it out, all the "release keys" are is a couple pieces of flat 1/2inch 18 gauge metal, they are about 4" long
2 Attachment(s)
here is a picture of the ones that came with my Sony but I am sure they are all the same
I think you need to pop off the little rectangular trim that would frame the detachable face to access the slots https://blazerforum.com/forum/attach...ine=1369350233 |
BTW the big end is what you hold on to and the little barbd hole hooks onto the deck to help you pull the unit out
all those pretty much do is push the "lock" on the metal bracket of the cd player out so you can pull the deck out. i have even used brass from a hobby shop.
(Post 585550)
I just figured a picture helps for somebody that doesnt know better |
I have some flat metal shims I can use, thanks for the advice guys. I am going to take it out today and wire in a new one. Then I am moving on to the speakers.
Which speakers are the easiest to replace? I was thinking the dash or doors. |
| All times are GMT -5. The time now is 12:14 AM. |
