Running Power/Ground Wire
Dont run the ground from the front to the rear first off. Make the ground as short as possible.
As for running the power from the front to the rear, Along the frame is your best bet and then entering the cab in the rear in a good spot. That many runs of 1/0 through the firewall would be nearly impossible.
Could I use some PVC pipe to run it under the Blazer?
cide
May 1, 2009 01:07 PM
