Running Power/Ground Wire
Old Apr 30, 2016 | 08:51 AM
Bigbodylexus's Avatar
Bigbodylexus is on a distinguished road
Default Running Power/Ground Wire
I have to add 4 runs of 1/0 gauge power and ground wire from the front to the back. Does anyone have advice as to make this chore easier?
Old May 1, 2016 | 09:19 PM
richphotos's Avatar
Dont run the ground from the front to the rear first off. Make the ground as short as possible.
As for running the power from the front to the rear, Along the frame is your best bet and then entering the cab in the rear in a good spot. That many runs of 1/0 through the firewall would be nearly impossible.
Old May 1, 2016 | 09:21 PM
Could I use some PVC pipe to run it under the Blazer?
Old May 1, 2016 | 09:54 PM
lazyboyjake's Avatar
lazyboyjake is on a distinguished road
There would be no need to. Just keep it all tucked up by the frame and you'll be good. Use zip ties
Old May 2, 2016 | 02:19 PM
Thogert's Avatar
^This, and I wouldn't trust PVC to protect anything anyway.
eljorgin
May 21, 2019 10:04 PM
L1VEEV1L
Sep 13, 2009 09:34 PM
cide
May 1, 2009 01:07 PM
ChevyRacing88
Mar 15, 2008 04:32 PM
88s10Blazer
Jul 23, 2006 06:52 PM
