Running Ground Wire
Old Mar 14, 2008 | 10:05 PM
ChevyRacing88's Avatar
ChevyRacing88 is an unknown quantity at this point
Default Running Ground Wire
So it was like 55 degrees out today and i decided to install my subs. Ran every thing fine, small problem was where to run my ground from my amp...only thing i can think of is running it to where my jack is and grounding it to the body, any one got any other suggestions? i was also thinking to unscrew the tie down hook screw and putting it in there but didnt think it would be good enough...
Old Mar 14, 2008 | 10:07 PM
Default RE: Running Ground Wire
Whatever you do, just make sure that you clean off the metal. The hold down clamp location would be good so long as it doesn't end up being a problem with sub placement and what not.
Old Mar 14, 2008 | 10:28 PM
navyblue_sk8er's Avatar
navyblue_sk8er is an unknown quantity at this point
If I remember that is where I hooked my ground to. Haven't had a problem with it.
Old Mar 14, 2008 | 10:45 PM
blazinloud's Avatar
and what year is this?
good spot is under the back seat in 2nd gens....
Old Mar 14, 2008 | 11:05 PM
98 LS 2dr..ok im gunna put it in my sig..lol
Old Mar 14, 2008 | 11:06 PM
ORIGINAL: ChevyRacing88
There ya go! Now you've just got to attach your sig!! HA!!
Old Mar 15, 2008 | 01:50 AM
Jharper's Avatar
Jharper is infamous around these partsJharper is infamous around these parts
best place i found on my blazer is to the seat bolt holding the seat down. never had any problems.
Old Mar 15, 2008 | 04:32 PM
theonetrueapex's Avatar
theonetrueapex is an unknown quantity at this point
I also unbolted the center backrow seatbelt and sanded off the paint and it has worked great.
eljorgin
May 21, 2019 10:04 PM
cide
May 1, 2009 01:07 PM
88s10Blazer
Jan 3, 2007 01:13 AM
burcham
Dec 5, 2006 02:29 AM
88s10Blazer
Jul 23, 2006 06:52 PM
