Setting the gain
Old Jan 14, 2007 | 04:41 PM
hillbillyinOhio's Avatar
Default RE: Setting the gain
right click and hit savetarget as. or go to www.realmofexcursion and click on downloads tab and test tones are there.
Old Jan 14, 2007 | 05:01 PM
blazinloud's Avatar
check out 'bass i love you' if you didnt already.......
people are pretty surprised when they hear that in my truck, not the loudest, but damn, do you get excursion!
Old Jan 14, 2007 | 06:10 PM
nofear17bmx's Avatar
nofear17bmx is an unknown quantity at this point
I got the file downloaded but when I burn it to a cd via WMP it says converted then complete and the disc pops out. I am worried it has converted it from a wav file to a wma or mp3 or somthing and if that happened I am not getting the quality I should be getting which would through off my gain setting. How would you burn it if you were doing this?
Old Jan 14, 2007 | 06:15 PM
Blazin_Jason's Avatar
If you can get it to play it your blazer it'll be just fine.
Old Jan 14, 2007 | 06:20 PM
I also downloaded the 50 hz test tone and burned it via WMP and it converted it automaticly (to what, I am not sure...) When I listened to the file after it was burned I could easily tell the quality loss after ti was burnt. So how do people burn these without loosing the quality?
Old Jan 14, 2007 | 08:19 PM
blazinloud's Avatar
I believe mine goes to mp3........well on my moms comp, not this pos [:'(]
Old Jan 14, 2007 | 08:56 PM
if you guys just make a data cd, using drag and drop in windows, it will burn as whatever you want it to.
Old Jan 15, 2007 | 12:10 PM
When I got my amp I got a paper that said that my amp is certified to 929 rms not the 750 on the box. Should I set my gain pertaining to the 929 rms or 750?
Old Jan 15, 2007 | 12:22 PM
929. and the target voltage for that is 43.1. I hope thats not too much power for those subs. it might be.
Old Jan 15, 2007 | 01:00 PM
Ok well I just set it for 750 since I wasnt sure at the time. I set it with the HU volume at 28 then I turned it up one (29) and the volatage jumped up to 44. So my question is, will I be damaging anything if I play it above 28?
I downloaded "Bass I Love You" and played it after the settings were correct. The subs sound fine but I have my speakers at the following settings:
Low: -8
Mid: 3
Hi: -9
Yet when I play the song there are certain spots where I think what I am hearing is my speakers distort. Thing is, when they distort in the song its not playing any high notes from what I remember.
