slight problem after installing system...
Old Apr 1, 2007 | 02:39 AM
vagnozzi's Avatar
vagnozzi is an unknown quantity at this point
Default slight problem after installing system...
No lights on my dashboard, the 2hi isn't lit up, but my turn signals and flasher works, odometer/gear selector shine, and on my new stereo not all the buttons are illuminated.
I checked the guage fuse, its fine. Question, I was able to remove the front dash panel without disconnecting the headlight switch, but I can't remember if I disconnected the switch for the dimmer, or if one even exists. Behind the headlight switch panel, are there two plugs, or only one? I think that I forget to re-connect something possibly, does it sound like my dimmer switch is disconnected, if there is indeed a plug for it?
thx
Chris
Old Apr 1, 2007 | 02:43 AM
hillbillyinOhio's Avatar
Default RE: slight problem after installing system...
yea, there is a plug for it. that one is really easy to pull back out. just make sure that everything is plugged in. let us know what you found out.
Old Apr 1, 2007 | 03:02 AM
vagnozzi's Avatar
thanks for the fast reply! so you're saying there are two plugs behind the headlight panel, right? Sounds like I forgot to plug one in if thats true there are two back there. Let me know if thats true
Old Apr 1, 2007 | 03:28 AM
on my 97 there is 4. hatch release, rear wiper and headlings and dimmer control. your hatch release is on other side i believe
Old Apr 2, 2007 | 06:02 PM
vagnozzi's Avatar
Yep, I'm an idiot. When I pulled the dash off, the dimmer switch unplugged by itself, so I didn't even know it was laying behind unplugged. Thanks hillbilly! I just plugged it in and was good to go!
ussexplorer
Sep 27, 2013 03:38 PM
Kipper667
Jun 2, 2013 03:05 PM
96realwe
Dec 10, 2010 09:19 AM
Eraston
Apr 4, 2010 11:34 AM
WhiteTie BlackJacket
Feb 13, 2008 03:22 PM
