Sony Xplod 1000 watt amp
Is this a good amplifier to power the two jl audio 12 in subs that i am buying?
RE: Sony Xplod 1000 watt amp
In no way would I call a Sony Xplod a "good" amp...What JL's are you buying and what power do you need at what ohm load...You need to be more specific so we can help you find what you need. "Sony Xplod 1000w amp" tells us absolutely nothing but a brand name and a made up power number...
bottom line, no. They are called "xplodes" for a reason.
just give us a price range, these guys can hook you up.....please, do not buy that sony amp.
sony "XPLOD" means explode its self because its junk.
I just realized that no one has mentioned yet WHY they are junk. sonys (and most mobile audio products sold at walmart) are bottom of the barrel equipment. Sony amps in particular (post 1990), are completely over-rated meaning that they dont actually produce the rated power they say they will. They are made with cheaper internal components (the caps, resistors, mosfets,etc...) so the reliability is thrown out the window. You can waste your money on the sony amp if you want, and it might work for you for a while, but you will be buying a nwe amp to replace it within 2 years maximum.
Look for an amp in your price range and post back with the model #
suggestions include kicker, alpine, hifonics, rockford, in other words spend an extra $50 and get clean power.
ORIGINAL: bobditts
The only good thing Sony has nowadays is the Playstation 3.
Who knows if that will go downhill along with the Sony name?
my sony digi camera is pretty decent for under $200
and if bluray wins the hd battle, it will be a huge boost for them.
