Sony Xplod 1000 watt amp
Old 12-16-2007, 10:33 PM
Mr Blazer LT is an unknown quantity at this point
Default RE: Sony Xplod 1000 watt amp
ORIGINAL: blazinloud
and if bluray wins the hd battle, it will be a huge boost for them.
So far, i've heard blu-ray is winning the disc player sales. Plus it sounds like blu-ray is the better quality format. I won't be investing in either anytime soon though.
Old 12-16-2007, 10:40 PM
Idriveachevy's Avatar
Idriveachevy is an unknown quantity at this point
Is a Directed 750d a good amp? i can get one used for 150.
Old 12-16-2007, 11:00 PM
cloak01ls's Avatar
cloak01ls is an unknown quantity at this point
Directed arent the best out there, but I would definately put them above sony...Make sure you are matching ohm loads and power ratings man. Not matching your subs to your amp usually results in a very depressing outcome...
Old 12-16-2007, 11:20 PM
do you think i should bring my subs to my local audio shop and say get me somthing cheap but decent?
Old 12-16-2007, 11:32 PM
cloak01ls's Avatar
I would advise you not to talk to a salesman. Some are trustworthy but most of them will lie to get you to buy something. If you could tell me what model JL's you have an what the voice coil configuration is I could reccomend a few amps that are decently priced for you...
Old 12-16-2007, 11:39 PM
well theyre jl audio 12w3 v2's but i dont know wat the voice coil config. is on them, i'd have to ask hillbillyinohio, cause hes selling them to me, or he can just butt in and say it, cause i have no idea
Old 12-17-2007, 12:29 AM
cloak01ls's Avatar
That model came in three diffirent configs so once you find out which one it shouldnt be hard to find a decent amp at a good price. 600wrms doesnt cost too much in the mid-grade amplifier category...
Old 12-17-2007, 05:28 AM
blazinloud's Avatar
Id just get the DEI
Old 12-17-2007, 09:55 PM
The subs are Dual 4 ohm vc's
Old 12-18-2007, 12:47 AM
cloak01ls's Avatar
ORIGINAL: Idriveachevy
Since you have two Dual 4's then you will need an amp that does 600wrms at 1 or 4 ohms. It looks like the directed amp is rated 600wrms @ 1ohm, so that amp should work just fine. You'll most likely only get 450-500wrms out of it but that should be plenty to run those subs...
Quick Reply: Sony Xplod 1000 watt amp
