Speaker glitches
Old Mar 7, 2010 | 04:56 PM
Jonas's Avatar
Jonas is on a distinguished road
Default Speaker glitches
Recently me left dash speaker has started to glitch alot.
Most of the time its just dead, occasionaly when driving on bumpy roads it kicks in then to be dead after a while.
I checked the radio, nothing wrong with it. so i figure its the connector on the speaker that must be glitching.
Is this a common problem with the blazers ?
Anyone have any experience with this before?
Best way to check the speaker connection ?
Thanks
// Jonas
Old Mar 7, 2010 | 05:18 PM
shmew22's Avatar
shmew22 is an unknown quantity at this point
Sounds like your cable may be coming loose from your speaker. Just pull that speaker out and make sure the harness is in there good. Should just be 2 screws holding in the plate that covers it.
Old Mar 8, 2010 | 11:32 AM
Jonas's Avatar
ok, i removed the 2 screws and removed the cover, to be able to get the speaker out, there was some more screws, wich i didnt have with me today... but now the speaker is working currently so il leave it until it stops again
Old Mar 9, 2010 | 03:33 PM
Jonas's Avatar
Default okay..
okay, so the left side went dead on me again.
the speaker in the driver door is dead, the speaker in the dash plays verry high tones verry low... its not the connection behind the stereo....
is there like a connector somewhere for all the left side speakers?
Old Mar 9, 2010 | 05:45 PM
shmew22's Avatar
No there isn't a dedicated connection just for left and right speakers. Only 3 problems it could be is 1) You have a wiring problem from your headunit to your speaker or 2) (unlikely) Your left channels on your headunit are dead or 3) Your left speakers are dead. What i would do is pull the HU and splice into the speaker wire from your headunit and plug into your speaker. If it plays its a wiring problem. If not then your left with either speaker or the HU. Test with one of your good speakers and if it plays then you need new speakers. If not... get a new headunit.
Old Mar 9, 2010 | 06:00 PM
Jonas's Avatar
It has to be the wireing, actually i tried with 3 diffrent HUs and for every one of them i had these symptoms.
Where should i start looking at the cables ?
How does the cables run from the HU ?`
HU -> Dash Speaker -> Door Speaker ?
Old Mar 10, 2010 | 06:51 PM
shmew22's Avatar
I wouldn't even look for the fault in the wire honestly. Id say go to wally world and pick up a spool or two of speaker wire and run some new stuff. It'll help in the long run. Especially if you decide to upgrade your speakers in the future. But if you wanna find the fault id start by looking in between the doors and see if it was pinched inside the grommet
Old Mar 10, 2010 | 07:34 PM
86Blazer4x4's Avatar
86Blazer4x4 is an unknown quantity at this point
these ac delco speakers are very poorly made. they will just go out for no reason at all. i would just say replace the speakers.
Old Mar 10, 2010 | 09:17 PM
shmew22's Avatar
yea, id go ahead and do that too... they are really crappy.
c3478493
Feb 3, 2014 02:56 PM
RedBlaze
Aug 19, 2005 10:59 PM
hyperlite_rider
Aug 1, 2005 05:39 PM
*TLR*
Jul 8, 2005 07:19 PM
02 Vortech
Apr 13, 2005 11:27 AM
