Speaker question ???
Old Apr 1, 2012 | 09:24 PM
4x4blazerguy's Avatar
Question Speaker question ???
On a 1998 Blazer LT do you have to pull the door panel to replace a speaker or do the grills come off?
I know this might be a stupid question but I'm not into speakers or radios. I just turn them on & listen. This Blazer has an OEM radio/CD. My right front door speaker is blown out & vibrates real bad. I was just going to replace it with a speaker from Walmart or an inexpensive speaker.
Any advice & info would be appreciated. Thanks
Old Apr 1, 2012 | 10:36 PM
50lb_cat's Avatar
Yes you have to remove the panel. Its really not hard at all. There's a couple screws by the door handle. The trim around the door handle comes off. Then gently start pullin on the panel. Its held on by plastic "christmas trees".
Old Apr 2, 2012 | 01:33 PM
Chuk Rhodes's Avatar
Chuk Rhodes is on a distinguished road
Walmart might sell a little set of plastic prybars for removing door panels. I bought them elsewhere, and it's worth a few bucks. You can get a small box of the clips at auto parts store, some may break or just not go back tight.
Old Apr 2, 2012 | 09:35 PM
Thanks Guys. I have a door panel removing tool that gets under the plastic push pins. I have some spares also. I was just hoping the grill would come off. The one in the door on the right side is blown bad. I found a good used GM speaker on Ebay I might bid on.
Again thanks.
Old Apr 2, 2012 | 10:07 PM
50lb_cat's Avatar
Yeah that would be too easy to just unscrew the grill lol. It had been awhile since I took my door panel off but its 3 screws. 1 on the door handle trim, and 2 at an angle below the door pull.
c3478493
Feb 3, 2014 02:56 PM
hockeykid15
May 5, 2007 02:51 PM
mrsuenos
Feb 22, 2007 12:43 PM
88s10Blazer
May 25, 2006 02:05 PM
02 Vortech
Apr 13, 2005 11:27 AM
