speakers
Old Dec 27, 2009 | 10:39 AM
irishdude's Avatar
irishdude is on a distinguished road
Default speakers
Hi I am just new here but I have a simple question. Would anybody know the size of the speakers in the doors of a 2000 Blazer and also what is the easiest way to replace the,. Thanks
Old Dec 27, 2009 | 12:23 PM
nj4x4blaze's Avatar
Do you have a 4dr or 2dr?
Old Dec 27, 2009 | 12:28 PM
88s10Blazer's Avatar
88s10Blazer is an unknown quantity at this point
6 1/2 I believe all the way around. The easiest way is to take out the screw by the door handle and grab yourself a trim removal tool and work your way around the edges. You can see the white snaps if you pull the panel back a bit. Just put the tool behind the snaps and pull it out of the door(not the door panel). Be careful and I would grab a couple more snaps from Auto Zone just encase. Then once all the clips are removed just pull it panel up so it will get past the window lip. Unhook the window/lock harness and your good to go.
Old Dec 27, 2009 | 12:57 PM
ABN31B's Avatar
to replace, remove 2 bolts, and yank the door panel off. then chop the wires, drop yours in and wire up. :icon_sub:
as for size... try the A/V section... it will have a ton of help. like this little gem
Old Dec 27, 2009 | 02:23 PM
irishdude's Avatar
It is a four door I was hoping it could be done without taking the door panel off.I guess the speaker grill that is showing is moulded to the panel. Thanks for your help
Old Dec 27, 2009 | 02:32 PM
Sisk's Avatar
** Moving to Audio/Visual Board **
Please be sure to read board descriptions before posting so you ensure you post in the correct board. If you head to the Audio board there is a sticky thread with Blazer stock speaker sizes.
Old Dec 27, 2009 | 09:15 PM
ABN31B's Avatar
thats what i linked
pctechdude
Nov 24, 2009 10:23 PM
2001blazer
Dec 4, 2005 10:21 AM
blazerrider101
Nov 7, 2005 11:04 PM
mharrison
Sep 11, 2005 02:34 AM
ChumleyEX
May 2, 2005 10:48 PM
