Speakers cutting out
Old Jul 19, 2010 | 11:05 PM
tjwiens91@hotmail.co's Avatar
tjwiens91@hotmail.co is an unknown quantity at this point
Default Speakers cutting out
This has just started happeing about 2 weeks ago. ill be listening to the radio at a normal volume not to loud and the drivers side speaker will start cutting in an out the passenger side doesnt do this just the drivers. could it be a loose wire? or is my speaker going out?
Old Jul 19, 2010 | 11:18 PM
84BlazerS10's Avatar
I'm not an expert on both but I would assume it could be both but more than likely your speaker is going out.
Old Jul 20, 2010 | 01:29 AM
ImScrewed92's Avatar
I figure it's either one of two things. Either;
A. You're speaker wire is loose and causing to move with the air pressure of the speaker making it cut in and out. Or
B. One of the speakers tinsel leads, (The wire that goes from the wire terminals to the cone of the speaker), has come loose and is causing it to cut in and out. I had a sub do this once. If it cut out, and you moved the loose tensil lead around, or pushed gently on the cone it would work agian and then cut out and on etc etc.
I would say it's deffinantly that perticular speaker that is the problem. Hopefully it's just a loose wire on the terminal or into the harness if it's a factory speaker. But if the speaker needs replaced, either hit a salvage yard for a OE replacement, or just replace them all with a aftermarket CD player and be amazed at the diffrence, lol .
Good luck.
adam.lee.person
Aug 11, 2008 07:43 AM
justDrivin
Apr 7, 2008 06:13 PM
Blazerx85
Nov 8, 2007 06:13 PM
RCarp48
Apr 30, 2007 12:59 PM
xtreme01blzr
Oct 18, 2006 03:23 AM
