Stereo Issues
Old Nov 23, 2015 | 04:26 PM
brent1010's Avatar
brent1010 is on a distinguished road
Default Stereo Issues
Hi, I installed a Kenwood aftermarket stereo years ago in my 2002 Blazer. Most of the time things have been working fine. Over the past couple months I've been having the following issues.
1) Radio does not usually stay on when turning key to off position, sometimes it immediately shuts off, other times it takes a few seconds to a few minutes. It should stay on until I open the door. Also turning to accessory does not turn on stereo. All other electronics, lights, windows seem to work fine.
2) This is even more intermittent and rare, but sometimes when using the power windows the radio will restart (power off and power back on), sometimes it even seems to be consistent with applying the brake pedal.
3) When the above things are not happening all of my speakers are usually not working at once, some work others don't, and sometimes they all work and sound great. I have all the speakers homing back into an aftermarket amp and then speaker wire going to my aftermarket stereo from the amp.
Could this all possibly be related to a bad ground cable connection for my stereo?
Old Nov 24, 2015 | 10:03 AM
Toocute350's Avatar
Toocute350 is on a distinguished road
That could be a number of things.How did you hook the wires from the new stereo to the factory wires?Did you use the aftermarket wire harness that comes with the install kit?Or did you just hog tie them together?What about the grounds for both amp and stereo..What are they grounded to..The grounds have to be connected to a clean area with no rust,paint or dirt in between the connections.There`s also a safety device that the factory installed with the factory radio`s,not sure what it`s called.I would suggest you to contact Crutchfield.com.They will be able to tell you more about this device I`m talking about.I`ve read that while replacing factory radio with a aftermarket radio,you will need to buy this device in order to be able to keep the same safety features you have now.Ex: Radio stays on for about 10 minutes, after you turn the ignition off,radio turns off when you open the door .
Old Nov 27, 2015 | 04:19 PM
brent1010's Avatar
I used the aftermarket wiring harness. I took the dash all apart again yesterday and looked at all the wiring. I noticed there are two black wires, are these both ground connections? Should I use them both to the ground wire on the harness?
I have to admit my ground for my amp wasn't the best. It is mounted to a bolt under one of the back seats. I cleaned off all the paint really well this time and will see if it helps.
Old Dec 1, 2015 | 04:42 PM
brent1010's Avatar
So far this has been working well since my last post. I really think it was the amp ground causing issues and not clean enough. Thanks!
Old Dec 1, 2015 | 05:51 PM
CWBDDSPC's Avatar
CWBDDSPC is on a distinguished road
Nice job, thanks for the update!
Old Jan 15, 2018 | 05:11 PM
Besel53's Avatar
Besel53 is on a distinguished road
Is there any way to replace the radio lights? Most of mine are burned out.
chase91
Oct 20, 2013 12:52 PM
satphonebrad
Aug 1, 2012 07:52 PM
evinrude
Sep 15, 2010 10:37 AM
hyperlite_rider
Apr 4, 2005 02:43 PM
custom blazer
Dec 28, 2004 11:23 PM
