Sub help
Old Feb 4, 2009 | 07:31 PM
tjwiens91@hotmail.co's Avatar
tjwiens91@hotmail.co is an unknown quantity at this point
Default Sub help
I would like to put a 10" sub in my blazer, but im worried about taking up space. I use my blazer to haul an assortment of things, ice fishing gear in the winter, paintball stuff in the summer. and on the way to tournaments i usually get the back packed completely full. is there any other things that might work? I do know about the Bazookas, and the ones that are all built in to one, Im thinking that that is my best bet becuase if i need to haul things i can just unplug wires. Does anyone have any other opinions? I know this has been covered an im a complete noob when it comes to sound.
Old Feb 4, 2009 | 07:35 PM
jagblazer01's Avatar
Default RE: Sub help
you can always make it so its easily removable with quick disconnects or dare I recommend a JL stealthbox
Old Feb 4, 2009 | 08:53 PM
Im onlny 17. Cant afford it. I can get a all in one Power Acoustic 10' 800 watt system for about $125.
Old Feb 5, 2009 | 10:18 AM
onecrazyfoo4u's Avatar
onecrazyfoo4u is an unknown quantity at this point
I'm in the same boat, I haul stuff several times a week in my blazer. I'm just going to mount the amp under the rear seat most likely, so that the only wires coming up to the 'truck bed' loading area are the speakers wires. I'll use quick disconnect connections for the speaker wire, and the box is going to be velcro'd down. So when I need the space and have to remove my 13" sub, it's really quick and easy.
Old Feb 12, 2009 | 05:46 PM
iroc2nv's Avatar
iroc2nv is an unknown quantity at this point
Hey jagblazer, they only make those for 4 dr. an i have a 2 dr. What do you recomendfor that ?
Old Feb 13, 2009 | 12:26 AM
BudRacing's Avatar
BudRacing is an unknown quantity at this point
Check out my install on my cardomain page. 2nd page. I can remove my sub within one minute or move it around to accommodate the load.
Old Feb 13, 2009 | 10:03 AM
iroc2nv's Avatar
I checked that out, good reading. Thanks
Old Feb 13, 2009 | 08:02 PM
WhiteTie BlackJacket's Avatar
WhiteTie BlackJacket is an unknown quantity at this point
One ten will not take up much room, and like everyones saying about the quick disconnects and all, it would be no problem to take it out
Old Feb 13, 2009 | 10:35 PM
What do people use for quick disconnects on there sub wiring? Anything special, or just the usual 1 male, 1 female connectors?
sifd4x4
Oct 5, 2009 09:13 PM
don mecca
Mar 21, 2008 09:12 PM
felonyblazer96
Dec 7, 2007 11:29 PM
Zasder
Nov 17, 2007 09:50 AM
rick465
Aug 25, 2006 09:37 PM
