sub problem
Old Jul 26, 2008 | 09:21 PM
pimpinblazer91's Avatar
pimpinblazer91 is an unknown quantity at this point
Default sub problem
ok so i got a set of polk audio momos 12" for free so i put them in ive had them in for about a month now heres my problem when the subs on it makes a ratteling noise but when its off and you push it in and out it goes smooth without resistance or noise ( i have a ported box) then when its on again and you put your hand on the dust cap it stops ratteling and sounds normal again is this sub blown if so is there a way to fix it or is i not even worth it another question is if its not worth it whats your opinions on fi audio 15" either the ssd or the bl or maybe even the q whats your opinions? thanks
Old Jul 26, 2008 | 09:24 PM
Default RE: sub problem
forgot to mention its only one sub thats doing this
Old Jul 26, 2008 | 11:58 PM
bobditts's Avatar
bobditts is an unknown quantity at this point
is the dustcap loose or coming off at all?
Old Jul 27, 2008 | 01:37 PM
no its still on there good
Old Jul 27, 2008 | 06:56 PM
clean89blazer's Avatar
clean89blazer is an unknown quantity at this point
How much power are u running. I have seen this before when u use to much power on a ported box. sometimes u can use stuffing in the box and see if that works.other then that thats all i can tell ya with the info u gave.It is easier if i can talk to over the phone to explain.Let me know.
Old Jul 27, 2008 | 07:34 PM
i only have a alpine 600 watt rms ampon it which isnt much and that amps gain is turned up half way and the bass boost is around 1/4 of the way if that what more do you need for info?
Old Aug 2, 2008 | 09:17 PM
yea screw it i got a new kicker zx 1000 on tha way so now i have another amp to match my zx350 for my door speakers and hopefully a new fi audio 15" bl will be on my door step i'll keep you posted on the progress
dimmuborgir6nik6
Apr 4, 2008 06:23 AM
felonyblazer96
Nov 26, 2007 07:32 AM
2001blazer
Nov 7, 2005 11:36 PM
BlaZeR FXB1581
Aug 19, 2005 11:08 PM
BlazerSquad93
Feb 18, 2005 05:06 PM
