Subs are popping and its not cool!!!
Alright, So To start i Have 98 blazer :]
I have 2-12 subs http://www.crutchfield.com/S-1fmtNNj...s-Package.html ... And http://www.pioneerelectronics.com/PU...rs/DEH-P4100UB Head unit.
Few months ago I hooked up my subs..
all honkey dorey.
The power cord to the amp from the battery broke.
Waited till now To get a new cord.. So after i hooked everything all up. I turned it on and my subs.. are going Pop pop pop pop pop.. With out any music whats so ever.. I disconnect the RCA's to - HU. or even just the speaker wire from the amp to the subs.. and it stops...
I have tried a new ground didnt do anything so if anyone has anything on why or how to fix this Or need more info Please let me know!!
Thanks in advance!
Thanks in advance!
and inline filter is just a bandaid for a bullet wound. Meaning its just going to mask a much larger problem. My guess is that you have cheap RCAs. Try a new set of RCAs and it should fix your problem.
http://www.knukonceptz.com/productMa...y=RCA%20Cables
Thats What i heard about inline filters. I also thought it might be the RCA's But even when i unplug The Speaker wire from From the amp To the actuall subs. Its Stops. So again any ideas.
also make sure your rcas are not near the power wire. i found out that's why i was getting the popping after that i ditched the filter. but the best thing is to go to the local car audio shop and pay um $25 to trouble shoot it!
Yea, Or the RCA's. I heard it could be a bad ground so i did a completly different one.. Just confusing seeing as it worked a month or 2 ago.. could putting the subs in a differnet spot in the truck change anything? Again Thanks for all your help. By the way.
NEW INFO!!!!!!!!
Okay... So I re undid everything all over again!!!!
Now Its still making the rapid popping noise once both rca's are in But when I leave just the "R"(Right) or the red Port in the AMP I can hear bass from the music quite alright... but as soon as i plug in the "L"(left) or the white port in the AMP it goes rapid popping.. I switched around the RCA's (thought it was a bad cord) but still the same thing happens so its not the cord.
this time any ideas any similar problems?
