Sundown Audio Nightshade
Old Dec 8, 2007 | 01:56 PM
blznlowxtreme's Avatar
blznlowxtreme is an unknown quantity at this point
Default RE: Sundown Audio Nightshade
pretty cool. im still thinking of switching my subs, looks like somemething to consider
Old Dec 9, 2007 | 12:35 PM
blazinloud's Avatar
40.9 watts @ 133.0 dB
141.1 watts @ 137.8 dB
311.3 watts @ 140.7 dB
513.4 watts @ 142.7 dB
811.5 watts @ 144.5 dB
1731.2 watts @ 146.9 dB
2845 watts @ 148.1 dB
4505 watts @ 149.2 dB
7081 watts @ 151.2 dB -- Still gained 2 dB at this point, very little compression
/S Specs for 12" D1 model:
Qts = 0.403
Qms = 6.830
Qes = 0.428
Fs = 43 Hz (fresh without break-in)
VAS = 11.65 L (fresh without break-in)
Le = 1.41 mH (series)
Re = 1.59 ohms
Xmax = 20 mm
BL = 17.58 N/A
Old Dec 9, 2007 | 01:33 PM
those are some pretty good numbers, it only requires 141.1 watts to match wat mine can do when wired at 800 watts
Old Dec 9, 2007 | 02:01 PM
blazinloud's Avatar
also its worth mentioning that the box used in testing was not optimized for spl.
testing was done with 4 1500D's strapped.
Oh! and im not postive, but im pretty sure this was done in a concrete reinforced vehicle, if im thinking about the same thread [&:]
Old Dec 9, 2007 | 10:07 PM
cloak01ls's Avatar
cloak01ls is an unknown quantity at this point
ORIGINAL: blazinloud
BL = 17.58 N/A
kind of a low motor force for an SPL oriented sub. The MT is all the way up at 54, which is a number ive yet to see ANY sub come close to. But, on the other hand, that tight coil gap is what makes me hate reconing MT's...
Thogert
Oct 4, 2014 12:46 AM
jagblazer01
May 8, 2012 08:14 PM
panthersfan101
Jan 21, 2010 06:56 AM
