tape deck wiring connection?
Old Jan 1, 2009 | 01:49 AM
streblo's Avatar
Default tape deck wiring connection?
just a quick question, the aux tape deck that is in the center console. i have yet to pull out the stock deck and just want to get a few things in order wiring wise for the new deck before i pull **** apart. how does the tape deck connect to the actual deck. is it just by 2 rca wires? (white red)
Old Jan 1, 2009 | 02:39 AM
cr8390's Avatar
cr8390 is an unknown quantity at this point
Default RE: tape deck wiring connection?
no it does not use rca's it uses this plug:
These are the pins:
Pin
Wire Color
Circuit No.
Function
LT BLU
1405
Tape Player Signal - Remote - Audio Communication
GRY
1220
Dimming Signal (except Envoy)
BARE
701
Drain Wire Return
DK GRN/WHT
368
Remote Radio Signal - Right Audio
BRN/WHT
367
Remote Radio Signal - Left Audio
BLK/WHT
372
Remote Radio Return - Audio
13
BLK
1050
Ground
14
DK GRN
835
Diagnostic Signal - Entertainment and Comfort
15
ORN
340
Fuse Output - Battery
Old Jan 1, 2009 | 10:22 AM
streblo's Avatar
ah perfect thanks, there is no adapters out there to convert that to an rca so that it can be hooked up to a aftermarket deck via rca cables i take it then?
what do most of you guys do with that tape deck? keep it ?
if i cant hook it up im thinking about just replacing it with a plastic cover and putting some switches on that cover for accessories. ex. fog lights
what are some suggestions
Old Jan 1, 2009 | 10:57 PM
cr8390's Avatar
there maybe a connector but its not really worth it if there is just get a new deck. As for the tape played i pulled it out and made a custom swtich panel from a old motherboard
Old Jan 3, 2009 | 10:53 PM
streblo's Avatar
ya i think i will end up doing something similar to what you are doing. throw in a switch for fog lights i added, and for a few other accessories that i put in. i wired in some heated seats and right now they are just always hot in run so i might throw a switch in for those as well. and afew other things i might put in.
interesting idea about the motherboard im going to have to search something out cool to make the panel out of
warthogdriver
Sep 4, 2013 12:10 PM
KdogTN
Sep 12, 2008 07:36 AM
Karcinagin
Sep 8, 2008 03:29 AM
josh05
Aug 29, 2008 04:04 PM
Smoked
Jun 25, 2008 01:47 AM
