toggle switches
Old 07-20-2008 | 12:50 PM
NVANZEE's Avatar
Default toggle switches
I have some LED's in my blazer. I want them to be able to turn on when the dome light goes on and i want to be able to turn them on at anytime even if the dome light is off. I found a switch that i think will work but is says its for 125VAC. Will this work for my blazer or not. If it does would this work how on want it to. http://order.waytekwire.com/CGI-BIN/...FD5072+M37+ENG
Old 07-20-2008 | 02:55 PM
bobditts's Avatar
bobditts is an unknown quantity at this point
Default RE: toggle switches
your link doesnt work. Sounds like you will have to wire up a complicated array of relays.
Old 07-20-2008 | 03:40 PM
NVANZEE's Avatar
here is the website http://www.waytekwire.com/index.htm the item number for the switch is 44207.
Old 07-22-2008 | 06:49 PM
NVANZEE's Avatar
so can anyone help me. will this work or will i still need to hook up some relays
Old 07-28-2008 | 11:53 PM
NVANZEE's Avatar
anyone????
Old 07-28-2008 | 11:55 PM
packofqtips's Avatar
packofqtips is an unknown quantity at this point
just have then turned on by 2 relays one realy turns on with the dome lights and one with a switch
Old 07-29-2008 | 12:03 AM
You could use one relay with a double trigger. Some diodes can be used as to not back feed into the dome light circuit. A great resource for 12v electrical setups is the12volt.com.
Old 07-29-2008 | 12:36 AM
NVANZEE's Avatar
since it is an on-off-on switch with 5 terminal would i be able to wire it so i could leave it fliped on on way so it will go on with the dome and fliped the other way to turn it on manually. also will this switch work for 12volt.
Old 07-29-2008 | 12:41 AM
If it is a SPDT or DPDT switch, then yeah, you could supply +12V constant to one 'throw' of the switch and then have the dome light circuit supply +12V to the other 'throw' of the switch.
Old 07-29-2008 | 01:00 AM
NVANZEE's Avatar
ok thanks
chris015
04-05-2012 07:00 PM
96jimmyslt4x4
04-27-2011 07:46 AM
portcqb
08-28-2009 01:09 PM
vin791
12-06-2008 06:59 PM
vin791
11-26-2008 10:07 AM
