Trouble installing system
Old Feb 11, 2008 | 08:08 PM
XBlazer01's Avatar
XBlazer01 has a spectacular aura aboutXBlazer01 has a spectacular aura about
Default RE: New system! Pics...
Dont just paint over the cone of the woofers. it will add weight to the woofer itself and can contribute to suspension sag.
Old Feb 12, 2008 | 03:12 PM
WhiteTie BlackJacket's Avatar
WhiteTie BlackJacket is an unknown quantity at this point
ORIGINAL: blazinloud
looks clean, wish I had a tan interior
Ill trade ya if yours is dark gray [8D]
Thanks XBlazer...is there any way to make them look better? Heres what the actual subs look like
Old Feb 12, 2008 | 03:38 PM
cloak01ls's Avatar
cloak01ls is an unknown quantity at this point
Wow, those are some gnarly looking cones, heheh...You need to get some dustcaps man, having the pole piece exposed is a good way to have horrible sound and possible malfunctions if something were to find its way into that hole. Secondly, if you havent allready it would be a good idea to disable the horn mids and tweeters. That way they arent robbing power from your subs. And last but certainly not least, You might want to invest some time and money into constructing a new enclosure...
EDIT:
5" Poly Dustcap
5" is the biggest they carry, should be enough to cover those ugly glue marks from the original dustcaps...
Old Feb 12, 2008 | 04:13 PM
XBlazer01's Avatar
omg O.O
You need dustcaps NOW
That is really bad.
Old Feb 12, 2008 | 04:27 PM
Haha I warned yall they were rough lookin...I think my buddy has the other dustcaps, should I glue them back on or just get new ones? That box is sturdy though, just needs refinished. Ill probably do that when it warms upin thespring or summer
Old Feb 12, 2008 | 04:37 PM
XBlazer01's Avatar
do the dustcaps first!
cause at this point you can get dirt/debris in between the pole and the voice coil and will then rub. Which will in turn blow your woofers.
Old Feb 12, 2008 | 04:40 PM
Ok, what kind of glue should I put them back on with?
Old Feb 12, 2008 | 04:54 PM
XBlazer01's Avatar
a light coating of a rubberized sealant/glue should work.
Old Feb 12, 2008 | 05:04 PM
Like rubber cement?
Old Feb 12, 2008 | 06:08 PM
XBlazer01's Avatar
http://www.soundspeakerrepair.com/sp...lies/Supplies/
that'll work
