Viper 560XV HELP!!!!
Old Aug 16, 2009 | 07:49 PM
92K5BLAZER's Avatar
92K5BLAZER is on a distinguished road
Default Viper 560XV HELP!!!!
ok so i have a viper 560xv car alarm, remote starting system. I recently bought some new remotes, and programmed them for the alarm and remote start. But when i went to try the start it turned the engine, started it then killed as soon as it started. before i programmed them, the remote start worked fine. so im asking what did i do wrong and how do i fix it?
Old Sep 1, 2009 | 02:42 AM
tesshin's Avatar
tesshin is an unknown quantity at this point
I'm in the same situation right now with my 791, I recommend disconnecting the brain and letting it reset it self. Well that's what I'll be doing tomorrow/today. Check all the connections as well.
Old Oct 16, 2009 | 08:20 PM
92K5BLAZER's Avatar
anyone, a little help?
Old Oct 16, 2009 | 08:21 PM
Probably a question better put to Directed Electronics tech line...
Old Oct 19, 2009 | 07:16 PM
hillbillyinOhio's Avatar
What were the steps that you did to program the remotes? You might have to go into programming again and reprogram the r/s. Did you install this yourself? Did you run a tach wire or go voltage sense??
Carrico4
Aug 2, 2011 10:59 AM
Carrico4
Aug 1, 2011 10:02 AM
tetricyde
Sep 13, 2009 06:14 PM
92K5BLAZER
Jul 16, 2009 05:46 AM
SanfordBlazer
Jun 26, 2009 06:27 PM
