How do i get through the firewall?
Old Oct 9, 2009 | 09:07 PM
offroadwnc's Avatar
offroadwnc is on a distinguished road
Question How do i get through the firewall?
i got everything i need bought and im starting on it tomorrow. Only thing i been wondering all day is where on earth i run the power cable to the battery and through the firewall. I pulled back the carpet on the passenger side and found a plug type deal but looking under the truck i think it sits behind the wheel well but i dunno. where did yall run yours and how should i do mine? thanks guys
Plus its a 2001 ZR2, since it seems they changed alot in 02
Old Oct 10, 2009 | 02:14 PM
FlatTopFoley's Avatar
FlatTopFoley has a little shameless behavior in the past
https://blazerforum.com/forum/showth...ght=power+wire
on my 96 I have mine going though the drivers side hole above the brake pedal.
Old Oct 10, 2009 | 05:41 PM
bobditts's Avatar
bobditts is an unknown quantity at this point
follow the fuse box wiring. This works on EVERY vehicle.
Old Oct 11, 2009 | 09:29 AM
offroadwnc's Avatar
thanks yall. i found a spot in the big rubber piece on the drivers side where all the wires come through. can i ask real quick though, do i need the inline fuse holder? cuz my amp has fuses
Old Oct 11, 2009 | 10:02 AM
bobditts's Avatar
the inline fuse is to protect your wiring, not your amp. If your wire is longer than 18", yes, you need an inline fuse (must be within 18" to the battery)
Old Oct 11, 2009 | 05:00 PM
Zeeke98's Avatar
Zeeke98 is on a distinguished road
Why go on the drivers side? Then you have to either go to the fusebox lug or cross over the engine bay to get to the battery. On the passenger side, find the antenna wire that goes through the firewall. The rubber around it is large enough to put the amp wiring through.
Old Oct 18, 2009 | 11:41 AM
02CKblazer's Avatar
02CKblazer is on a distinguished road
yup thats what i did. works good and cant be seen =]
Old Oct 18, 2009 | 10:29 PM
oktain's Avatar
That's where my power cable runs!
Old Oct 19, 2009 | 10:47 PM
rastoma's Avatar
rastoma is on a distinguished road
joshn444
Apr 25, 2013 08:05 AM
carterx
Nov 30, 2009 01:39 AM
djkrash
Jan 8, 2008 03:23 PM
EuroGoldLS
Jun 15, 2007 04:11 AM
Kaffeene
Apr 25, 2007 10:03 PM
