well.......once again, with out fail, another problem
Old Jun 14, 2011 | 03:47 PM
m3ch's Avatar
m3ch is on a distinguished road
Default well.......once again, with out fail, another problem
so i forgot to ask the other day but i have another problem
this time with my amp, i have no idea where to post but here it goes
my amp will not turn on unless the remote is touching the power, i cut the remote wire, nothing, i cut it up where it connects to the radio, nothing
so...........ideas?
forgot to say, it is just a sony xplod 1000 watt amp
Old Jun 14, 2011 | 08:54 PM
rriddle3's Avatar
Originally Posted by m3ch
...this time with my amp, i have no idea where to post but here it goes...
*Moved to 'Audio/Video Electronics'*
Old Jun 14, 2011 | 10:50 PM
blue_zr2's Avatar
blue_zr2 is on a distinguished road
does the remote have power? maybe the remote hooked to the back of the radio isnt a good power sorce..
Old Jun 15, 2011 | 12:17 AM
96jimmyslt4x4's Avatar
96jimmyslt4x4 is on a distinguished road
Yes, you need to hook the remote input to a 12v+ wire to power the amp on.
You can have this on the ignition 12v+ of the car (the one that turns the head unit on when you put the car into ignition position or accessory position)
You can also have a switch hooked up to turn it on manually.
Usually, people hook it up to the remote out of the head unit.
Old Jun 15, 2011 | 03:24 AM
m3ch's Avatar
i have hooked up many amps to the head unit using the remote out on the head unit, to answer your question yes i did have it hooked up there, and well, now idk whats going on, do you think i can run it off of one of the 12v+ wires that actually powers the head unit it self (having 2 wires in on 1 doesnt sound like a good idea) or where should i hook it up at, cause it seems to me, that the remote out on the head unit (also a sony xplod) more than likely died on me, and im tired of having to touch the remote + 12v wire on the amp to get it to work and undoing it etc etc
i guess i can experiment later today, hopefully i dont blow my self up =D
Old Jun 15, 2011 | 07:25 AM
altoncustomtech's Avatar
Yes you can connect it to the switched power wire on the HU. Chances are you accidentally shorted the remote wire to ground at some point while the HU was on and blew the little internal fuse or circuit that controls the remote out. As long as the source is switched with the key you can connect the remote wire to it.
Old Jun 15, 2011 | 06:42 PM
m3ch's Avatar
welllllllllllllllll i feel dumb.........it was just the remote wire itself that was bad
Old Jun 15, 2011 | 06:54 PM
LOL, glad you found the problem. Sometimes its the simplest things that escape us when beginning to troubleshoot. Looks like ya got it figured out before you spent too much time on it though. Happy Bumpin'!
Old Jun 15, 2011 | 07:45 PM
m3ch's Avatar
well, up next is to build a box i think im going to get some 12" Pioneer subs
Old Jun 15, 2011 | 08:39 PM
What's your budget on the subs? There's a great possibility that you could get something much nicer than the pioneers, with a better warranty and in most cases that is rebuildable if it fails or if you just want something different/bigger/smaller for the same money or maybe just slightly more than you're going to spend on the Pioneers. There's a TON of great subs on the market, you should really shop around and find the best bang for your buck first.
