WHAT DO YOU THINK
Old 02-03-2007, 11:46 PM
livlifes2short's Avatar
livlifes2short is an unknown quantity at this point
Default WHAT DO YOU THINK
OK I Have A 93 Blaze I Just Installed A Head Unit With Forty By Four With Sub Front And Rear For Amps Also Installed Pioneer ts-p462 Plate Components And Diamond D362.5I 6.5 I Have A Power Acoustic 600 Watt Amp Should I Put Them On The Amp Will It Sound Better More Bass Cleaner Sound And Less Distortion At Higher Volumes? When I Went From Stock To After Market Head Unit On The Above Mentioned Speakers There Was A Huge Difference Can I Expect A Noticeable Change With The Amp? Thanks In Advance
Old 02-03-2007, 11:52 PM
hillbillyinOhio's Avatar
Default RE: WHAT DO YOU THINK
Yes, very noticable difference. much cleaner power, more control. Do it.
Old 02-04-2007, 12:02 AM
Sweet One More Question I Am Going To Run The Power And Remote Wire Down The Driver Side And The Speaker Wire And rcas Down The Passenger Ride. Where Is The Best Place To Run The Wires Up To The Radio And How When I Ran My sat Radio Wire From My Overhead Console It Was Almost Impossible To Get To The Head Unit? Thanks In Advance
Old 02-04-2007, 12:28 AM
just run under the carpet until you get to the kick panel, remove the screw, take said kick panels off. you will have to run behind the glove compartment. pull out the radio and fish a coathanger that way. you will eventually get lucky. or, you can take out the dash speaker, cut the wires to that speaker, and tape on new wires, fish a coat hanger up to that opening. pull the wires up to the dash speaker location. then take cut wires, and tape the new ones to it. pull back from radio opening.
Old 02-04-2007, 12:36 AM
Also When I Use My Aux In The Rear Or Front I Get Engine Whine On The Radio Its Fine And When I Ran My Sat Radio Through The Tape In The Original Radio I Had No Noise? What Do I Do Thanks In Advance
Old 02-04-2007, 12:44 AM
what kind of HU???? you have grounding issues, at least, maybe more.
Old 02-04-2007, 11:46 AM
ITS A INSIGNIA GOT IT AT BESTY BUY CRAPPY UNIT I KNOW BUT ALL I COULD AFFORD WITH REAR INPUTS AND ALL THE AMP OUT PUTS WILL UPGRADE IN A FEW MONTHS SO UNTIL THEN. DO YOU THINK IT IS A BAD GROUND ON THE SAT RADIO THE ONLY TIME I GET THE WINE IS WHEN I USE THE AUX IF I PLAY THE SAT RADIO OVER THE FM TRANS ITS FINE THANKS AGAIN
Old 02-04-2007, 12:08 PM
nofear17bmx is an unknown quantity at this point
Sorry if this is totally of topic, but how hard and how long does it take you to right your posts with the beggining letter of every word being capitalized lol
Old 02-04-2007, 12:34 PM
blazinloud's Avatar
i was thinking the same thing!! hahahaha
Old 02-04-2007, 12:50 PM
i believe that you may have an issue witht he outputs (jacks) on that cd player.
Quick Reply: WHAT DO YOU THINK
