what high output alternator to go with
Old Feb 9, 2010 | 06:53 PM
  #21
zedartwo's Avatar
Originally Posted by ryankinder82
i talked with kinetik and im going to go with the 160 amp alternator and a hc2400 battery. they said that would be plenty for what i have. ill let you know how it goes.
Awesome! How much did that battery throw ya back from them?
Old Feb 9, 2010 | 07:09 PM
  #22
ryankinder82's Avatar
ryankinder82 is on a distinguished road
i got the battery for $229 and the alternator for $159.
Old Feb 9, 2010 | 07:13 PM
  #23
zedartwo's Avatar
Did you get the battery right from kinetik?
Old Feb 9, 2010 | 07:59 PM
  #24
no they wanted $499 and i new i could get it cheaper from a place i get all my stereo equiptment from.
Old Dec 20, 2010 | 09:10 AM
  #25
ExplicitYourSelf's Avatar
ExplicitYourSelf is on a distinguished road
Sorry to bring rhis up from the dead but hows your setup up going now that you have upgraded your alt and battery, which brand and model alternator did you go with after all? i
Old Dec 21, 2010 | 01:57 PM
  #26
blazinloud's Avatar
h.o alts are a waste imo unless you have multiple batteries, or a really tiny factory. most are built into small stock casings and rewound with thicker wire allowing less room inside the alt causing more heat buildup, which is bad. put alot of research in before you buy one is all i can say.
Old Dec 21, 2010 | 02:58 PM
  #27
altoncustomtech's Avatar
^^ That is true for most HO alts. DC Power for sure and supposedly Excessive Amperage, Irragi and Mechman build REAL HO alts with parts that are truly designed for the job. However, you're also not going to get one for <$300 either that's built properly like that. It takes power to make power and when you're wanting to get serious like buying an HO alt you're going to pay to play, that's just the way it is.
Browse DC Power's website and look at the comparison on their website here -> https://www.dcpowerinc.com/dc-power-vs-competition
It can give some good insight to what it really takes to truly produce a lot of current, along with the rest of their tech articles.
Don't forget to do the BIG 3 as well. Upgrading the alt to batt positive, batt negative to frame, and engine to frame wires with at LEAST 4awg, preferably larger will help even with the stock alt but is an absolute necessity with an HO alt.
Old Dec 21, 2010 | 07:48 PM
  #28
blazinloud's Avatar
i notice a pretty big difference in my alts ability to keep up from cold to hot.
Toby Hanson
Dec 13, 2012 01:19 AM
59f-100
Sep 4, 2012 02:03 PM
rc1626
Feb 8, 2011 11:52 AM
jagblazer01
Mar 1, 2006 07:16 PM
