Wiring?
Old Mar 25, 2007 | 04:17 PM
RCarp48's Avatar
RCarp48 is an unknown quantity at this point
Default Wiring?
I was wondering when you wire your subs up- When you connect the positive and negative do you just use the regular speaker wire with the positive strand and negative strand connected or do you seperate the wiring- Need help
Old Mar 25, 2007 | 04:54 PM
hillbillyinOhio's Avatar
Default RE: Wiring?
either way is fine. as long as you dont switch the polarity, no worries
Old Mar 25, 2007 | 06:53 PM
nai0013's Avatar
nai0013 is an unknown quantity at this point
Default RE: Wiring?
It's all copper (probably) as long as you hook pos to pos and neg to neg. I don't know what you mean seperate them? What kind of speaker wire are you using?
Old Mar 25, 2007 | 10:56 PM
blazinloud's Avatar
Default RE: Wiring?
dont you reverse the polarity if there inverted
Old Mar 26, 2007 | 01:15 AM
viper4559's Avatar
viper4559 is an unknown quantity at this point
Default RE: Wiring?
You can never assume that the negative wire is truely your negative wire, you must always check to make sure it is in fact going to a negative terminal on whatever you are connecting. Same with positive. You can reverse the wires and it will still work, just as long as you keep the negative end from your source connected to the negative end on your destination. That's why things are marked + or - so we could easily find out which wire is connected to +/-. But it never hurts to double check, because in the off chance that they are switched then you are out some money.....
Old Mar 26, 2007 | 01:19 AM
bigjsp's Avatar
bigjsp is an unknown quantity at this point
Default RE: Wiring?
Many cross overs come with a phase inversion switch, test it out to see which sounds better,particularly if you are mixing brands of mid basses and subs.
You can alway do the battery check to be sure the + causes the speakers to all move in the same direction, some cheaper subs may not.
Old Mar 27, 2007 | 06:41 PM
RCarp48's Avatar
Default RE: Wiring?
What im trying to do is change my subs from 2ohms (paralell) to 4ohms series and im wondering when wiring this, my speaker wire has a + wire and then a - wire and i was wondering when wiring the ohms do I jus use Normal speaker wire with the + and - or do i use one or the other? and from what ive been told sometimes when wiring the ohms differently, you sometimes connect the + terminal and - terminal together with speaker wire. Is this right, and if it is how do i do this?
phxjosh
Oct 30, 2013 10:03 AM
speedhead
Mar 16, 2012 06:54 PM
nineteensixtycaddy
Sep 12, 2010 08:54 PM
joshzerofour
Feb 15, 2005 11:37 PM
chris
Dec 6, 2004 12:47 AM
