Wiring up a Remote Start, Door Locks Don't Work
Old Jan 12, 2009 | 03:14 PM
NTL1991's Avatar
NTL1991 is an unknown quantity at this point
Default Wiring up a Remote Start, Door Locks Don't Work
I'm sure someone here has installed an alarm or remote start on their truck with power locks. I'm having an issue with them on my Bravada. I'm supposed to tap into the Keyless Entry Module above the driver's side knee bolster. There are wires going into the module; light blue is the lock wire and white is unlock. When I bought the truck it didn't come with the keyless entry remote(s) but the module is there and it's plugged in, but after tapping into it, I'm not able to lock the doors. I'm sure the remote start is good and the wiring to it is all good, but I'm wondering if there's any fuse that controls the Keyless Entry System or anything like that.
Would I be able to tap into the wires at the driver's door switch? I guess it would be the same unlock/lock wires...
Nick
Old Jan 12, 2009 | 03:58 PM
Default RE: Wiring up a Remote Start, Door Locks Don't Work
You may have to use relays. I do not know if you can tap straight off of these wires. Also, do you know if you have a negative trigger or positive trigger at the RKE module?
Old Jan 12, 2009 | 08:47 PM
oakleyg's Avatar
oakleyg is an unknown quantity at this point
You should test your wiring with a DMM before you go hooking things up, they are probably a negative trigger. Try testing some of the wires coming out of the door boot, or others at the plug for the keyless module and see if any of those will work. You could also go inside the door and get them at the switch but the ones coming out of the door boot would be easier.
Old Jan 13, 2009 | 03:49 PM
NTL1991's Avatar
They are, in fact, 12v positive trigger (Type-A), and the previous owner had the t-taps already installed on the correct wires. I removed them and installed new taps, but I'm not sure if the wires were cut somewhere down the line. I will just get the wires from the driver's side power window/lock switch. The colors are the same white and light blue...
Nick
Old Jan 13, 2009 | 11:28 PM
xmradioguy's Avatar
xmradioguy is an unknown quantity at this point
this should help you a little
[IMG]local://upfiles/4934/BD628030052B4286AF1E7EF870D814A2.jpg[/IMG]
project85
Jan 15, 2015 03:23 PM
pswizzle
Mar 12, 2012 03:50 PM
dustie hunter
Jun 12, 2011 06:27 AM
ussexplorer
May 11, 2011 09:04 PM
88s10Blazer
Lifting Tech
34
Oct 17, 2010 02:50 PM
