02 BEAST build
Old Aug 5, 2015 | 06:27 AM
  #41
Tajohns34's Avatar
That is a lot of motor for that little car. Should be awesome!
Old Aug 5, 2015 | 08:28 PM
  #42
TMM217's Avatar
TMM217 is on a distinguished road
Was considering doing the BJ spacers too. Did you ever contact Airbaggit about the fitment?
Old Aug 7, 2015 | 07:35 AM
  #43
Mrthelaxer's Avatar
Mrthelaxer is on a distinguished road
Thanks TaJohns34, it's gonna be a really slow build but I'm really looking forward to getting the motor started and running.
TMM217, I did contact them, they asked me to send them a picture which I will be doing today, it sounds like they are willing to give me a refund which will helpful. Also the biggest thing for me is that they had serious rubbing issues on stock rims even with 1 inch wheel spacers on. I would suggest holding off on them unless you have 16 inch rims or bigger otherwise you may damage the rim or at a minimum have some really frustrating rubbing
Old Aug 7, 2015 | 08:04 AM
  #44
Jamaroon's Avatar
Are you still running the wheel spacers? Do the back of the wheels have enough of an indent to allow the wheels to mount properly?
Old Aug 7, 2015 | 12:02 PM
  #45
Mrthelaxer's Avatar
No I removed them because the wheel was rubbing pretty significantly and rather than messing with it I took them out because the blazer is now going to be used as a hauling vehicle while we work on the new Triumph project
Old Aug 10, 2015 | 09:03 AM
  #46
Mrthelaxer's Avatar
I put the upgraded MPI injectors in to help stop any fuel leaks and hopefully regain some of the fuel economy I used to have. The engine works great....to great I somehow made it so it wont die.
after taking the video it took me about 15 minutes to check the connections and get it to run normally again.
Old Oct 11, 2015 | 02:00 PM
  #47
Brauman's Avatar
Brauman is on a distinguished road
looks great man! so just to confirm to your lift stuff here, you have an add a leaf in the rear with a 2" shackle and only a one inch ball joint spacer in the front??? I wouldn't mind doing something like that to mine!
Old Oct 15, 2015 | 12:09 PM
  #48
Mrthelaxer's Avatar
I have the add-a-leaf and 2" shackle in the back and I took the front spacers out but I did have 1" spacers and a torsion bar crank. I would say the ball joint lift is worth it if you have larger rims that will not rub on the wheel hub.
Old Oct 16, 2015 | 07:05 PM
  #49
newguy's Avatar
Keep an eye on your upper a arm for cracking with the BJ spacers
CraigSnedeker
Oct 31, 2012 08:16 PM
kiwiblazer
Dec 29, 2008 01:51 PM
dimmuborgir6nik6
Mar 9, 2008 04:28 PM
cliro
Dec 15, 2007 10:35 PM
boomtruck97
Suspension Tech
Sep 8, 2006 02:56 PM
