1997 blazer sas solid axle swap
Old Aug 14, 2013 | 07:35 PM
  #41
xillzxnickx's Avatar
xillzxnickx is an unknown quantity at this point
i wanted to part out the jeep but im only 19 and still living with mom lol
the jeep couldn't sit on the property, have no way to remove car once the axle was out do have a father in law with a flat bed but I hate asking for favors and he thinks everything im doing to the blazer is crazy, and didn't want to pay for two retail fees of trailer.
I really wanted to take the rear axle out and whole drivetrain
Old Aug 14, 2013 | 08:28 PM
  #42
so today I started to clean up the axle and two of the leaf spring eye bushing I will show my way I of getting out.
so I put my small torch on a brick and let it do work
wait until it starts melting rubber and you can try to start hammering out
Old Aug 14, 2013 | 08:35 PM
  #43
sometimes the bolt comes out without rubber just hammer
thinking of having axle sand blasted at my house because it took to long to get little bit cleaned up with an air angle grinder
Old Aug 14, 2013 | 10:32 PM
  #44
Diaita's Avatar
Well, that's one way to get the bolts and bushings out... You can drive a small cold chisel into the gap where the spring wraps around the bushing and nearly touches the flat part of the leaf. Then the whole bushing with seized bolt will tap through.
Old Aug 14, 2013 | 10:46 PM
  #45
That works too pyro side got to me lol so maybe tomorrow I'm getting warn locking hubs in the mail but won't be installing to I reassemble after breaking down the axle
Old Aug 14, 2013 | 11:50 PM
  #46
jbb421's Avatar
jbb421 is on a distinguished road
Glad to see another build. My wagoneer spring bushings were so seized in there the only way i could get them out was how you did it.... I'm running 430 gears in my blazer with 35s, and it has plenty of low end way more than it did from the factory. Also its not bad at highway speeds. You are probably going to need one of these
OTC 7080 Ball Joint Spanner Wrench : Amazon.com : Automotive OTC 7080 Ball Joint Spanner Wrench : Amazon.com : Automotive
if you plan on replacing the balljoints mine has locking sleeves on the uppers and yours more than likely will too. part stores charge about double for the tool figured ied help save you a headache looking for it.
Old Aug 15, 2013 | 06:51 AM
  #47
I work at a shop and we have a ball joint tool but I don't think I've seen that attachment .... What year wagoneer did your axle cone from mine is a 1990
Old Aug 15, 2013 | 01:30 PM
  #48
abig84's Avatar
thats how i usually do them too, even on s10s at work i do them on the drive on lift, i just ilft the truck on the center of the axle. take a big ratchet strap and hook it to the leaf and back down to the lift, pull it down far and burn away. after i knock out the center like you did i take a air hammer and blow out the sleeve. dirty stinky messy job but oh so fun
Old Aug 18, 2013 | 05:15 PM
  #49
Does any know if my axle an 1990 grand wagoneer front dana 44 has a crush sleeve or not
Old Aug 20, 2013 | 01:20 PM
  #50
abig84's Avatar
can you define crush sleeve a little bit more? for the pinion or the steering arm?
