1997 blazer sas solid axle swap
so as far as a home remedy for this problem im not really sure. you can try using a cut off wheel which ive done for axle shaft bearings that got seized but you always risk jacking up the surface under the bearing. call some local shops see what they will charge to swap them out
I ended up bring the new ring and pinion and install kit to a friend of my boss and he set it up he's done many and does a lot of custom fab
Never covered it im getting a astro van pitman arm tomorrow and I messed up one of the tie rod ends so I need to re tap it ..... Today I re hooked up the exhaust and connected the blazer and bleed them but ran out of fluid
So all I have left is the steering pitman arm and stuff
Plus I have to trim more out of the upper control arm mount to mount my shock
Make sure you get the correct taper for the reamer. I've heard of guys getting an ironworkers reamer and calling it close enough(which of course it isn't)
I reamed it have all steering hooked and the god dam pitman arm hits well the bolt going through the pitman arm hits the engine mount on the frame side going to have to torch it alittle cant drive it down to the shop I work at
