2000 Blazer New Project
Torque arm links. The trailmaster lift came with extensions that you plug the new links into. The links are part number 15996064 from GM I haven't found a third party who makes these other than at napa. GM and napa wanted $45 each. I found them on ebay for $25. Just stuck the jack under the crossmember to support the weight, unscrewed them and screwed on the new ones. I also added locktite to the extenders.
I then hammered out the bushing till I could grab and pull it out with pliers. It will be hot as hell so be careful. I have some nice burns on my neck and arm from molten rubber splashing from the first swing of the hammer..
Aaaand a snag.. The site I got the Energy Bushings from said the 3.2129 Bushings would fit. They don't. Since I have the Z85 suspension, I actually need 3.2142 bushings. These have 4 2 inch wide eye bushings and 4 1.5 inch rather than 8 1.5 inch. Guess it will be a few more days.
New (correct) bushings are on the way... As I'm driving home I hear a loud bang and assume its the bushings... I get under it to check it and the rear upper driverside shock mount broke and the shock busted right through it... Anyone have any idea where I can get another?
