2000 Boring Blazer Build
Old 04-29-2018, 08:33 PM
Tajohns34's Avatar
So I didn't finish tonight because it got dark and cold. I got the wiring unwrapped, there was a massive amount of electrical tape on there.
Anyone notice anything wrong with the next 2 pictures?
Old connector
New Connector
In case nobody caught it, pin A (Park/Neutral Signal) is not connected on the old or new connector. It was just taped up in the harness. I never had an issue with it. I did see on some sights that it isn't used on all vehicles.
Here is the old connectors that I cut out.
Everything all hooked up
That is as far as I got today. I had a really hard time getting the butt connectors to stay on the wires from the vehicle because some of them are so thin, I wasted quite a few. I still need to wrap up the wires, connect the shift linkage and reconnect the front drive shaft. I did hook the wires to the Neutral safety switch to test it, it shows that it is in neutral, but won't start. I'll try again once it is all done. Also, The back up lights are still on....
  #352
Old 04-30-2018, 02:56 AM
Lefet's Avatar
Lefet is on a distinguished road
Nice job.
  #353
Old 04-30-2018, 03:03 AM
error_401 is on a distinguished road
Nice fix!
An option could be soldering and a shrink hose. But it's a lot of work.
  #354
Old 04-30-2018, 03:37 PM
Tajohns34's Avatar
Nice fix!
If these don't hold up that is the way I will go, but I really don't want to lay upside down under the car holding a soldering iron.
  #355
Old 05-01-2018, 07:06 AM
Yeah - and definitively a job to be done in nice weather and possibly on a lift or at least stands which make enough room
  #356
Old 05-01-2018, 08:15 PM
Tajohns34's Avatar
So I made a good bit of progress tonight, but didn't quite finish. However, I got to the point to where I can test it. The parking selector from what I can tell is dead on, even though the backup lights are still on the fritz.
Wires are all taped up.
All hooked up
The cap wasn't lining up, when I tried to fix it the cap fell off and needle bearings went all over the place. Thank god for magnets. I'll finish this up tomorrow.
  #357
Old 05-02-2018, 01:55 AM
Been there - done that.
What a PITA when the caps fall off. I have wasted 1 hour in the garage picking up the needles. Then removed the other side cap to count the needles. Luckily I have found all the needles.
Exactly what you need when putting all together.
  #358
Old 05-02-2018, 11:47 AM
Tajohns34's Avatar
Looks like I am out of luck, there is still one needle that I am missing, I looked all over the area that the fell and it is nowhere to be found. I even used a big magnet to find it.
  #359
Old 05-02-2018, 12:39 PM
chevyriders's Avatar
Ah man, thats rough. Been there before ...ended up having to replace it over one needle. I saved the old u joint in my toolbox though in case I ever need to salvage a needle from it lol
  #360
Old 05-02-2018, 03:50 PM
Tajohns34's Avatar
I got a moog u joint from advance for $19 after tax. I just put the end caps on it since I couldn't get the shaft all the way off or i would have replaced the entire U joint. I did keep the old ends.
Quick Reply: 2000 Boring Blazer Build
