2000 Chevy Blazer 4x4 engine replacement tips tricks
Old Sep 2, 2025 | 09:58 AM
Stovey's Avatar
Stovey will become famous soon enough
Failfree, I'm impressed that you removed and installed a new engine in a short period of time!
Regarding camshaft retard, I had to install an aftermarket bracket on the distributor to allow it to rotate to zero. The same aftermarket bracket is also used on a Chevy 350.
Old Sep 2, 2025 | 05:58 PM
int3414's Avatar
int3414 is on a distinguished road
i was looking on the jegs site..how does one know if they have an L35,,,?
Old Sep 17, 2025 | 12:30 PM
LesMyer's Avatar
L35 is an RPO code. Should say L35 on the glovebox sticker if you have one (and you should have one in a 1996-2002 Blazer). 2003+ Blazers had the LU3.
Bottom line, 1996-2000 L35 engines will work in 1996-2000 Blazers. 2001 - 2002 L35 engines will work in 2001+ Blazers. 2003+ LU3 engines will work in 2001+ Blazers. Reason is the mounting hole in the block for the knock sensor changed in 2001. They make adapters for this mounting hole (some better than others). Reason for a separate listing for 1999-2000 L35 engine is the transmissions in some vehicles required a different pilot hole size in the crankshaft for the torque converter (I don't believe this was the case for the Blazer).
IIRC the engine I bought for my 2001 Blazer from Jegs was a LU3 that they don't seem to have anymore.
If you are really asking how to tell if the Jegs engine is an L35, just read the title for the part.
Chevrolet Performance 12491867
Chevrolet Performance GM Goodwrench 4.3L 262 V6 Crate Engine 1999 Remanufactured L35
ldawg1346
Jan 12, 2015 01:16 PM
PseudoKirby
Jun 12, 2011 10:56 AM
Topgun
Oct 24, 2010 08:20 PM
cc4usa
Oct 31, 2009 09:22 PM
kgould67
Oct 16, 2007 12:49 PM
