2000 Turbo Diesel Blazer Benz mash up thread
Old Oct 3, 2009 | 07:47 AM
  #51
bigschmerm's Avatar
bigschmerm is an unknown quantity at this point
Thumbs up
I like that answer!
Old Oct 3, 2009 | 08:30 PM
  #52
ebachrville's Avatar
ebachrville is on a distinguished road
Lots of progress today:
Fabed up all the radiator supports and hoses ect..
hooked up the relay for the glow plugs and got the blazer oil pressure sender mounted, you can also see the throttle cable assembly here also: Note that that oil sender needs to be grounded so that the reason its mounted the way it was as a plastic hose would not ground it
And made the temp sender mounting for the blazer temp sender:
I also tackled some of that nasty wiring harness, since im using only 3 of the sensors , oil and temp and the gear selection switch, I'm cleaning up the harness so its easier to manage.. no pics of that.. yet
Old Oct 4, 2009 | 11:10 AM
  #53
Brianator99's Avatar
Brianator99 is an unknown quantity at this point
This is awesome. I'm enjoying reading your progress.
Old Oct 4, 2009 | 03:22 PM
  #54
Psychropod's Avatar
Psychropod is an unknown quantity at this point
Originally Posted by AJBert
Hopefully, GM hasn't totally scrapped the baby D-max 4.8L. Word on the the street is it will swap in the same as a SBC. Bit higher numbers than your Benz engine, too.
Pardon my ignorance, but what's "SBC"? It's a good idea to spell out acronyms the first time you use 'em, because everybody doesn't know what it is. LOL
I've also been considering a greener option for an engine swap, but I don't know if I want to go electric. A 4.8 diesel may be a fun thing to do.
Originally Posted by ebachrville
Nope, not a mechanic.. however I work on/maintain my own cars.. by profession I'm a multimedia/IT computer geek..
However cars are just another form of technology.
Exactly! I've been saying the same thing. I'm also in IT and like working on vehicles for the same reason. Love this thread!
Old Oct 4, 2009 | 03:24 PM
  #55
SBC = small block chevy
Progress looks good!! Keep up the good work!
Old Oct 4, 2009 | 04:34 PM
  #56
Today I totally redid the Blazers wiring harness, eliminating any plugs that were not used and taped up every thing to make it tidy.
I also made the mount for the coolant overflow tank, worked out well.
Added the power cable to the glow plug relay from the battery.
Welded some steel on to the upper radiator support so it can be bolted into place , yet easily removable for pulling the engine.. also made rubber mounts for the top of the radiator that secure it to the upper radiator support.
Also setup the vacuum line to the power break booster
No pics today.. sorry
Need to pick up some steel and bits to make the mount for the blazers gear selection switch and the linkages to the benz transmission tomorrow.
Old Oct 4, 2009 | 09:45 PM
  #57
Since this project came together as a dirt cheap project car i always leave no idea to question.. browsing the local Craig's list I came across a same gen pickup shell.. for cheap.. HMMM makes me wonder
Add a couple stacks in the bed and your really have a rig.. it probably would not be any longer than my 1 ton dually crewcab full size.. so it would be usable.
Probably wont do it but dang its tempting.
Old Oct 4, 2009 | 10:06 PM
  #58
Psychropod's Avatar
Dangit, I should have figured that one out. LOL
Old Oct 4, 2009 | 10:59 PM
  #59
packmule75041's Avatar
packmule75041 is on a distinguished road
Interesting concept - will be following your progress. I have long thought about getting one of those 5 cyl. MB's - so this is of particular interest to me. It's certainly a good use for the motor!!
Old Oct 4, 2009 | 11:02 PM
  #60
I need to stay away from Craig's list.. found that shell of a S10 and other shells of blazers.. and Benz 300d's that are rusted out for cheap.. I'll go broke making Frankenstein vehicles.. lol
