2002 Xtreme V8 LS swap
Old Nov 1, 2010 | 03:23 AM
  #81
lostbob44's Avatar
lostbob44 is on a distinguished road
Props. Keep it up
Old Nov 4, 2010 | 11:43 AM
  #82
1sexyblzr's Avatar
1sexyblzr is on a distinguished road
Your blazer is givin me an extreme chub haha sweet build bro
Old Nov 19, 2010 | 07:21 PM
  #83
02_5SPEED_BLAZER's Avatar
02_5SPEED_BLAZER is on a distinguished road
Originally Posted by Xtremechubs
Jared down at Current Performance took my stock 4.3 computer and reflashed it with the custom tune for a 5.3 with an LS1 intake with the cam and heads with the rocker arms i'm going to run
Then he built a custom wiring harness to make this a plug and play swap he eliminated the evap system the rear O2's and the vats system out of the computer and the wiring harness
The wiring is 100% brand new with brand new connectors and made for this motor in my blazer.
The plan on the motor is to paint the block, intake, valve covers, coils black then the coil brackets, fuel rails, throttle body, throttle cable bracket paint matched yellow i was thinking about doing yellow stripes in the groves in the valve covers. i think i'm going to paint the computer gloss black then put a GM performance division badge on it.
Hey bud ive been looking into doin this to my 02 blazer how much did u end up spending on the swap including ecm flash and tune and wiring harness without tranny cause im pretty sure my nv3500 will hold up to the 5.3. An also the guy that built you the wiring harness and flashed the ecm how much did he chage cause that sounds like the way to go on that.
Old Nov 20, 2010 | 01:26 AM
  #84
MTopper's Avatar
he bought everything brand new so his numbers will be higher than what you could do it for if you bought an ls1 or such with like 30K miles. over on s10forum he said he was in $9 grand and needed about 5 more.
Old Nov 20, 2010 | 10:58 AM
  #85
Thanks bud but do u know if i would be able to use the stock 5.3 wiring harness and plug and play with my ecm after its flashed or will i have to modify the wiring harness..
Old Nov 20, 2010 | 07:39 PM
  #86
MTopper's Avatar
i have no clue. i just read it on s10 forums. he comes in and out every so often
Old Dec 10, 2010 | 11:04 PM
  #87
Xtremechubs's Avatar
Xtremechubs is an unknown quantity at this point
Hey guys sorry for the big gaps between posts the build goes in and out of being my priority. The 5.3 harness can be made to plug and play but its pretty difficult from what i've experienced and read. I got my blazer to fire up on the stock 5.3 harness and then it shut right off. The VATS system was shuting it down which later on i found that the Vats on a 5.3 computer can not be bypassed by the wire in resistor. You have to get it tuned out of the computer. Jared @ Current Performance Wiring can hook you up if you want to send him a harness and have him modify it $450 or so or have him build a brand new one for about $900. The computer tuning ranges anywhere from $175 to $450.
Old Dec 11, 2010 | 12:49 AM
  #88
Default Update
I got the T56 back from the transmission shop the guy told me it would be between $250 and $1275. Well after he cracked the case i went down there and looked at it and the trans was f'd so it ended up costin me $1275 and he threw in some upgrades so its pretty nice now still got more to buy and more to do but i'll be getting to that shortly. Heres a pick of the trans now.
Before
Old Dec 23, 2010 | 06:46 AM
  #89
00Blazer4door's Avatar
00Blazer4door is on a distinguished road
Wow man, im loving this. I literally just read this entire post all in one go and loved every page. Im actually bookmarking this page bc i plan on throwing in a 5.4L from a 69 camaro real soon. I really cant wait to see the finished product.
Old Dec 23, 2010 | 10:31 PM
  #90
old skool luvr's Avatar
glad to see the project is still moving along Brett.
kinda sucks about the trans needing a complete tear down, but@ least you know it'll stand up to your abuse.
hopefully.
